Question about Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112)
Booting problem system not booting
  • GATES_man May 11, 2010
    What are your hardware specs.(RAM, HDD, CPU)? Your hardware must support the OS.
    Sergeant:
  • 199 Answers
Dear may be your CD is not bootable.
or may be your boot sequence order is dismiss.
check your boot sequence from motherboard setting and then try.if prbolem solve then rate me..i can further help u.
Posted on Apr 16, 2009
Lap top not booting
If you hit F8 just before it boots, there should be a menu that will let you repair or start the system with the last known good configuration. That may help you.
Jan 05, 2014 | Lenovo Computers & Internet
I have installed Ubuntu , due to some errors I uninstalled that software but the booting menu to select the OS is still coming. How I can able to change to the settings for automatically booting windows 8.
In system properties there are now 2 entries for booting your computer. You need to edit your system .ini file located in the windows folder.
you simply remove the line relating to the second boot option.
DO NOT remove any other text in here or your system will not boot again.
Sep 08, 2013 | WinZip 12.0 - Windows for PC
When booting desktop doesn't load
There are a couple of quick fixes you can do.
First, boot into Safe Mode (Repeatedly tap the F8 key while the system is booting, before the windows logo appears) A Menu will pop up, press Boot Into Safe Mode. From there you can try a System Restore to a known good date.
System Restore - Click Start -> Control Panel -> On the top right, type "System Restore" without the quotes. Click on "Restore system files and settings from a restore point". You can choose the recommended restore or a specific date.
The other option is to boot into "Last Known Good Configuration". To do this, use the F8 trick again while booting, but instead of Safe Mode choose "Last Known Good Configuration".
Please note that either of these run a risk of some data being lost from the time the restore point was made. You "shouldn't" lose anything but just want to make you aware.
If this helps please give a good rating. Thanks.
Jun 30, 2011 | Gateway Computers & Internet
Its still not running
Is your PC booting up properly. If yes then some of your system files of operation system got corrupted. Try boot the PC with a boot disk and reinstall the operation system.
Mar 13, 2011 | Computers & Internet
Computer is slow while booting
So many resion for system slowness,firsly depends on your system configuration,
booting depends upon your system RAM,how much RAM you user in system,min 1GB RAM require for smoth booting.second one is overload (tmp,recent,temparary internet files,cooks),delete all the files and restart the system.
check it issue will be fix,otherwise there was a problem with OS.
backup all the C drive data on anohter drive and reinstall OS in C drive.
Surly issue will be fix.
Thanks,
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Can someone provide me online recovery disk of gateway 7330gz
You must set the boot sequence of the system to cd/dvd rom first which will enable the system to look for booting files in the disc in the first instance.
In your case your system is booting direct from hard disk. Boot sequence can be changed ib the bios setup of your system.
In some laptop models the restore files can be accessed by pressing function keys while system starting.
Mar 12, 2009 | Gateway 7330GZ Notebook
Boot loader problem
I beleive that you are installed windows first and linux second,then dual booting will be configured automatically ,means linux will install the grub (boot loader)and configure it with what all Os u have.If your system is not booting and showing grub menu do one thing ,boot it from a linux cd and reinstall grub.
Oct 31, 2008 | Microsoft Windows XP Home Edition
Booting to Operating System
Have you tried booting from CD? Does it still happen? If so, your RAM might be damaged. Or it might be an overheating problem. Check the fan outtake for dust.
Oct 27, 2008 | Dell Vostro 1500 Notebook
System Booting Problem
ITS EITHER A HARD DRIVE OR A MEMORY ISSUE
Oct 15, 2007 | Computers & Internet
Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112) Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
