Question about IBM ThinkPad R60 Notebook
My Laptop Gives Hard Erroe On Blue Screen And Rebbot While Running Win Xp Sp-2
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    change RAM 100% Ram malfunc , or if u have 2 sticks try one by one or get another one for testing
I have acer 4741z, its having problem and already formatted hard drive, i tried to install win xp using installation cd, its running ok until the blue screen appear and struck there. How to install win xp,...
It is not a hardware issue. It is easy to install Windows 7 in your laptop but if you want to install Windows XP you have change the Hard Disk type to IDE. For that you have to change settings in your BIOS. After changing to IDE you can continue your installation normally as you done earlier...
thanks & regards
Anas K A
Jun 27, 2011 | Computers & Internet
When i start win xp setup from wintousb software bcz i want to install win by usb after loading win files it gives blue death screen technical info:...
try going into the system setup or bios screen and see if you can find a setting for SATA Operation or SATA Mode for the hard drive. if you can find this, select ATA or AHCI and test the installation again. hope this helps.
Apr 16, 2011 | Computers & Internet
Dear sir/mam I want to install win xp in a win 7 installed laptop, (compaq 510) but there was some error to install it (blue screen error). Sir please help me to install win xp the same system with...
You cannot downgrade Windows 7 from Windows XP by not reformatting the hard drive. You need to Remove Windows 7 first, before installing Windows XP Operating System. In order to use the Windows XP CD to fully reformat the Hard drive, follow the steps on the link below.
http://www.windowsxpprofessional.windowsreinstall.com/indexinstallguides.htm
Apr 04, 2011 | Computers & Internet
I cant install win xp in compaq cq 40 137 tu. which gives an error that there is no sata drive is present in the laptop
U can try edit your bios.
If cant, then u have no choice but to integrate the sata driver on your window xp cd...
May 09, 2009 | Computers & Internet
Can't instal xp on compaq vt 3717
its the feature of microsoft that it would not let install win xp on a computer with vista. what u can do is completely format the computer and use bootable xp cd and install .
Nov 02, 2008 | Compaq Presario Notebook
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
Blue Screen
OK, so I took out the added RAM, changed the internal RAM to a new 1GB stick. The machine booted, windows started, I logged on, then blue screen. I put the old internal RAM back in, changed the hard drive, same result. This test suggests that the RAM is fine as is the hard drive as the blue screen appeared with different hardware. My next step is to replace the motherboard as the appears to be the issue. I'll let you know how I get on.
Jul 17, 2008 | Toshiba Computers & Internet
Won't boot up to windows
Because of anti-piracy laws you will not be able to use your XP on the laptop. You will need to buy another xp to Install. Win 2000 pro is very prone to blue screen and crashes. You will need to re-install win 2000 pro.
When you buy and install xp it will reformat (wipe) the hard drive for you.
Jun 20, 2008 | Compaq Evo N410C Notebook
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r windows........win-xp-sp2
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | Seagate Momentus 5400.3 Hard Drive
IBM ThinkPad R60 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
