Question about Kenmore 88752 Top Load Stacked Washer / Dryer
No heat in a Kenmore stackable washer dryer
I have a Kenmore stackable washer dryer that the dryer has no heat The timer, element, thermistors all check out as good with an ohm meter, I checked the voltage on the timer also and it checks out good. Is there something I am missing is there somthing connected to the motor that affects the element in the motor wiring or somewhere else? Please help, it is driving me crasy.
    Genius:
  • 1,122 Answers
There should be a small fuse on the heater box,if that is not working the element will not work also-mike
Posted on Apr 16, 2009
Where's the fuse for heater box
Posted on Nov 14, 2009
Kenmore stackable washer/dryer model# 417.94702300. washer will not start after replacing heating element in dryer. what could be the problem? there is no power going to the timer. what could be wro
If it was working before you replaced the element, I would suggest that you have inadvertently knocked a wire off somewhere or trapped and cut through a wire. Have close look everywhere you were working.
Dec 26, 2014 | Kenmore Washing Machines
Kenmore stackable washer/dryer. Model 417.93802209. Dryer will run but won't heat. Flipped breaker. Suggestions?
Possible that the heating element has burnt out, or that the thermostat that controls the element is defective. If you have a low or warm setting try that also as it may use a different element? Good luck.
Jan 20, 2013 | Washing Machines
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
Dryer runs but no heat. Stackable set, dryer on top.
More than likely the Thermistors are blown. They are located on the heating element canister inside the dryer, they are kinda oblong shape with two electrical connections. If you have a multimeter you can check for continuity on the thermistors and the heating element just be sure to disconnect one of the electrical connections on the thermistors and the heating element so you don't get a false meter reading, Thermistors can be purchased from most appliance repair businesses for around $30.appliancguru.jpg
Dec 10, 2010 | Frigidaire FGX831CS Top Load Stacked...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a kenmore stackable washer and dryer no heat is coming out. but it goes around
the heating element is most likely fried, or thermostats need replacing
Jul 03, 2009 | Kenmore Dryers
Kenmore Stackable washer dryer. Dryer is not heating up. I need to find how to replace the element
The element is behind the drum. You have to remove the front panal and pull the drum out.
Eric
Jun 10, 2009 | Kenmore Dryers
Dryer spins but wont heat - element okay
HAVE YOU CHECKED THE MAIN FUSE FOR THE DRYER?WHITE AROUND THE SIDES AND DARK IN MIDDLE,UNSCREW THE KNOB COUNTER CLOCK WISE TO REMOVE KNOB,SHOULD BE 2 SCREWS HOLDING TIMER REMOVE THEM AND THE PANEL SIDE SCREWS,THANKS-MIKE
May 29, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
1,280 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
