Ecoquest Fresh Air Air Purifier
Problem for Ecoquest Fresh Air Air Purifier
I have a Fresh Air Unit from Ecoquest. The
By j1234b567 on Apr 16, 2009
I have a Fresh Air Unit from Ecoquest. The message says to replace "plate". Was wondering why I would have to do this as it looks fine?
Solution #1
posted on Jun 06, 2009
Not Rated)
gototech
Rank: Wiz
Rating: 91%, 25 votes
Call toll free 1-877-710-0057 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
Was this helpful?
Yes
No
Solution #2
posted on May 07, 2009
Not Rated)
Dutch7773
Rank: Wiz
Rating: 85%, 16 votes
When that message appears the plate does not make good contact with the two contact points. You can use rubbing alcohol and a q-tip to clean the points. After 1-2 years it is also advisable to change the purifier plate. Plates are about $15 and can be purchased at EcoQuest.com
If the plate is dirty (and this can unnoticeable grime-grease) clean the plate with 1 part clear ammonia and 1 part water. An old tooth brush works great.
Dutch
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Fresh Air Air
Questions and Unsolved Problems for Ecoquest Fresh Air Air
Do you recommend Ecoquest Fresh Air Air Purifier?
Answer
Answer
Hi, when I turn my Ecoquest Fresh Air Air Purifier on, it rapidly and irregularly turns itself off... (More)
Answer
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi... (More)
Answer
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest... (More)
Answer
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the... (More)
Answer
install plate? no i just cleaned and now it won't work. it says to install plate.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Purifiers Experts
Top Air Conditioner Repairmen
in , KY
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
