Question about Sony Ericsson Akono HBH-608 Wireless Headset
Sony HBH608 Bluetooth Headset
How can I resolve automatic disconnects
    Problem Solver:
If it is for ps3 got to home page then turn the controller off manually then turn it back on and it should work
Posted on Apr 06, 2008
SOURCE:
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Bluetooth headset disconnects for no reason
Established in 2003, Shenzhen Gblue technology Co., Ltd. specializes in research, development, design, manufacturing and marketing of Bluetooth products, such as Bluetooth headsets, Bluetooth headphones, stereo earphones, wireless mouse and some other consumer electronic products. Our products are well received worldwide due to our uncompromising quality and fashionable appearance. We have integrated production lines, so we could easily meet your requirements.Shenzhen G-Blue Technology Ltd. http://www.gbluetech.com
Nov 30, 2012 | Sony Ericsson Xperia NEO MT15i Unlocked...
LOST PASSWORD FOR SONY ERICSSON SGH-T469W BLUETOOTH HEADSET
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Mar 12, 2011 | Sony Ericsson Sony-Ericsson HBH608...
How can make a friendster? pls. teach me
Help can be found at http://www.informationzoo.com/Friendster.html just email them. They are really helpful
Feb 13, 2010 | Sony Ericsson Sony-Ericsson HBH608...
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing that...it workss....
Jan 03, 2009 | Sony Ericsson Sony-Ericsson HBH608...
Motorola Headset Out of range...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS815 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 23, 2008 | Motorola Mobility HS815 Wireless Headset
SAMSUNG BLUETOOTH PAIRING
4.Select (Serched bluetooth device) once a connection is detected.
Tips:
Dec 04, 2008 | Motorola Mobility Bluetooth Hands Free...
Not automatically connecting?
you'll need a stereo bluetooth (A2DP) headset...
your headset/handsfree profile will only play single channel (mono) stuff... i upgraded from an H700 to a Jabra BT8040 which will play my media... you can also try the Moto S9, people have seemed to like that one too... __________________
Aug 18, 2008 | Sony Bluetooth Wireless Headset for...
Bluetooth problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (serched bluetooth serched device) once a connection is detected.
Tips:
Jul 28, 2008 | Motorola Mobility Bluetooth Hands Free...
Sony Ericsson Akono HBH-608 Wireless Headset Logo
159 people viewed this question
Top Sony Ericsson Radio Communications Experts
Anthony Ward
Anthony Ward
Håkan Sterner
yobo007
yobo007
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
