Question about Bionaire BSF1731RC Stand (Pedestal) Fan
Fan blades are filthy!
Bionaire stand fan model #BSF1731RC - can't remove fan blade covers to clean. Can't find user manual with care/cleaning instructions.
  • 25 Answers
Put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Posted on Apr 16, 2009
How do I remove face cover to clean fan? It is filthy and disgusting.... Help!!!
can only guess but most have clips on the blade guard that allow you to take the cover off .the the blades has a screw that comes off to get the blade off .
Oct 21, 2015 | Dryers
The lights come on but the fan blade doesnt turn
Check the thermal fuse located inside the motor fan winding wire. Check the crystal oscillator and micro-controller located in the printed control board of the fan. When it is replace with similar type, the fan will function again and ready to be use.
Thanks for asking.
Jul 09, 2011 | Bionaire BSF1731RC Stand (Pedestal) Fan
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
Cannot remove blades
hi! there,
there are two type of removing the blade of electric fan,one is there is a center knob with mark arrow loosen and tight direction at the center holding fan blade, this to lock fan blade on its shafting. to remove fan blade.loosen holder knob on clockwise direction while holding the fan blade,to release the knob check the arrow on the knob. after loosening knob pull out blade from the shafting.
the other type the fan blade has lock in bolt at the back side of the fan blade bolt in on the shafting of the fan, you need here a tools such as set of socket wrench small one to loosen the bolt
after loosening lock in bolt, pull out fan blade.
besure doing this tha electic fan was unplug to elecrtic source. have a nice day.just rate me,thank's
Apr 18, 2009 | Heating & Cooling
How do I get my cool operator fan apart to clean the darned thing
hi! there,
well! no brand and model,anyway the guard fan has a quick clip lockaround the fan blade,be sure to unplug your electric fan before doing this, unlock clip lock then the fan has a quick handy lock knob at the center of the fan observed loosening knob there is direction arrow in loosening this if i'm wrong going counter clockwise,or take the direction indicated marked on top of knob.
pull out the blade and have it clean if this is a plastic or aluminum clean it with water and spounge/cleanser,avoid to distorsion on fan blade if happen this will wiggle when run again be carefull and on the second guard fan still connected to your electric fan,there is plastic lock nut release and pull out the 2nd fan guard,try to clean this with water and cleanser,the motor assembly with control and stand just wipe it out ,don't try to get wet specially the motor,let all dried up before reassemble.reverse the process to eassembly
Apr 04, 2009 | Dryers
Ceiling fan wobble
try taping a nickle on top of one of the blades start in the middle of the blade (from tip towards motor) then turn it on see if it improves..if not change it to a different blade.. keep trying blades till you notice an improvement. Then fine tune it by moving the penny in towards the motor or out towards the tip. It is a time consuming task but it will work.
Jan 29, 2008 | Bionaire BSF1731RC Stand (Pedestal) Fan
Nut problem
This might be a long shot, but have you tried turning the nut the opposite way? The nut will probably have to be turned the opposite way of the rotation of the blades. This might be the "wrong way". Some nuts are opposite to keep things from comming off. Like the nuts on the right side of my remote car to keep the wheels from falling off.
Jun 17, 2007 | Bionaire BSF1731RC Stand (Pedestal) Fan
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
539 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Steve F
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
