Question about Kicker ZX10001 Car Audio Amplifier
Kicker ZX1000 Open ground issue
My kicker Zx1000 amp has a major problem this is happening to my zx240 aswell.When i tap on the amp it comes through the speakers almost like a have a mic hooked up to it cant understand it .The amp is giving all kinds of nasty sounds popping crackling and when i play music it sound spacey and distance please help checked rca
  • Perry Babin May 11, 2010
    Disconnect the RCA and speaker wires from the amp. Do you have ~0 ohms resistance between the non-bridging speaker temrinals and the shields of the input RCA jacks?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kicker Master
  • 2,226 Answers
You probably have a bad ground to the rca's .
Posted on May 08, 2009
I have 2 kicker cvr15 4 ohm duel voice coil speakers how do i wire them to a kicker zx1000 amp??????????
The ZX1000 is a two ohm stable amplifier, so this means that you have to connect your two voice coils in series to give you around 8 ohms impedance per speaker, then connect your two speakers in parallel to give you 4 ohms impedance on the single mono channel on the amplifier. I recommend you connect it up in the following manner:
Apr 06, 2011 | Kicker Car Audio & Video
I've been running a kicker kx 800.2 and it has worked until now
Hello highryguy420,
It sounds like one or more of the output components is failing on the amp. You can contact Kicker support directly for instructions to return the amp for repair: support@kicker.com . Alternatively, if you have a local car audio shop that does component level repairs, they could perhaps save you some money and time.
Hope this helps.
Jul 14, 2009 | Kicker KX800.2 Car Audio Amplifier
I cant hook up my amp
Hello cesar199064,
These are the steps you required to install your amp and subs:
1) Purchase an amp wiring kit with 2 or 1/0 gauge power and ground wires.
2) Decide on a location to mount the amp where it will get proper airflow and will not interfere with operation of the vehicle. Closer to the battery is better. Decide on the location and install the sub enclosures.
3) Locate a place on the metal body of the vehicle within about 3" of your amp for the ground. Connect the ground wire to the amp ground terminal and to BARE METAL on the vehicle.
4) Run power wire from battery positive (+) using one of the amp kit ring terminals through a 100A fuseholder to the amp positive terminal. DO NOT install the fuse yet.
5) Run a "remote" wire from the remote turn-on lead (usually blue or blue/white) of your dash mounted head unit to the amp turn-on terminal. Run a set of RCA cables from the preamp or subwoofer outputs on the head unit to the amp inputs.
6) Run speaker wire, preferably at least 12-gauge, from the amp output terminals to your subs.
7) Check all of your wiring. Make sure that no insulation was damaged or peeled off during the running process. Make sure there are no loose strands touching adjacent terminals or bare metal.
8) Use a multimeter set to read "ohms" and test from the negative battery post to the amp ground terminal. You should read "0".
9) Install the fuse.
10) Turn on your head unit and listen to those big Kickers thump.
11) Adjust the amp settings according to your manual.
The best place I've found for in depth information on audio installs is The Install Doctor. You'll find step-by-step procedures, color photos, wiring details, and even the tools required. I recommend that you begin with the "tech docs" link and read through some of the PDF documents.
Hope this helps.
May 08, 2009 | Kicker ZX10001 Car Audio Amplifier
My Amp Keeps shutting off
You need to get an amp with higher wattage. Obviously, your amp cannot handle those two 10" monsters. hehe Nice Subs though :D
May 01, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
I have 2 s12l7 in a porte box and kicker zx1000 n pioneerdeh-5900
usually you want to set them about 2/3 of the way up and then adjust from there to the sound quailty you like.
Dec 18, 2008 | Kicker ZX10001 Car Audio Amplifier
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
My kicker amp turns off
It sounds like you may have the load impedance too low. How many voice coils per woofer? How many ohms is each coil? If you have DVC woofers, are the coils for each woofer wired in series or parallel? Are the speakers wired in series or parallel. Let me know if you need me to clarify anything.
Oct 05, 2007 | Kicker ZX10001 Car Audio Amplifier
What amp to use
recommended maximum for the sub boxes is 1600/800 here is the link to the manual if you need it; http://www.kicker.com/06/tech-support/manuals/manuals/2007/2007%20CompVR%20Box%20d01%20Web.pdf If you really wanted to get the maximum from your subs then a zx750, or possibly a zx1000 would be the ideal choice. Either amp you suggested will work, but you will have more fun with a 750 which should do fine. Hope this helps :)
Mar 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
Kicker zr360 amp
Double check that your ground wire is connected to the ground terminal, make sure the ground wire is not broken.
Oct 11, 2006 | Kicker ZR360 Car Audio Amplifier
Car Audio & Video Logo
170 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
