Galileo 800mm-72mm Refractor Telescope CC-872 w/ FREE UPS
Problem for Galileo 800mm-72mm Refractor Telescope CC-872 w/ FREE UPS
I have a gear and pinion that are chaffed a little, can we sand
By topotxjg on Apr 16, 2009
this is a boat inboard outboard motor and a bearing went bad and I had to replace them. While inside the gear box I see the pinion gears were a little chaffed, not bad but a bit. $400.00 to replace them. Can I sand them with a dremal and use a heavier rear end oil? If so what kind of sand paper and what kind of oil?
Clarification Request
Posted by Joe L on May 17, 2009
This question is posted in the Telescope Topic--
Solution #1
posted on May 18, 2009
Not Rated)
Joe L
Rank: Guru  Binoculars & Telescopes  Expert
Rating: 89%, 241 votes
You posted this question in the TELESCOPE topic instead of the boat motor topic--
You might have better luck receiving an answer inside the correct topic.
Was this helpful?
Yes
No
Popular Solutions for Galileo 800mm-72mm Refractor
Questions and Unsolved Problems for Galileo 800mm-72mm Refractor
Do you recommend Galileo 800mm-72mm Refractor Telescope CC-872 w/ FREE UPS?
Answer
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and battery number for a Tasco red dot Propoint PDP2
Answer
What is the voltage and number of the battery for a Tasco red dot Propoint PDP2
Answer
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or... (More)
Answer
This is a jason model 307. the telescope worked fine untill the gear teeth stripped. I know that it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Galileo 800mm-72mm Refractor...:
Top Telescope Experts
Rank: Guru Guru
Solutions: 3902
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
