SOURCE: Logitech Harmony 670 universal remote
Greetings Hendon,
The close captioning your looking for would have more to do your television or video source then your remote control.
Depending on how you receive your broadcasting you may want to make basic adjustments to your other equipment. If you receive it through your television you should check your television setup menu for something along the lines of "caption", "CC", or "Text". As well if you receive broadcasting through a cable or satellite box their setup menus should have options for similar options.
I hope this helps.
Jon
Go Ahead. Use Us.
SOURCE: Abilities of Universal Remotes
Yes!
When you define different activities (such as Watch TV, Watch DVD, etc.) the remote will ask which of the TV inputs your device is plugged into. After programming, when you select the appropriate activity, the remote will automatically select the correct input.
SOURCE: harmony 659 won't learn samsung LN-52A850S1F remote
Samsung has recently acknowledged an issue with 8 series LCD TVs (e.g. LN52A860). When the TV is first turned on, it outputs strong IR interference which can render the Harmony unable to control your devices for several minutes. After the TV is warmed up, the interference dissipates and the Harmony will work correctly again.
To determine if your Samsung television is causing the issue:
1. Start an Activity that uses your Samsung TV
Confirm the Harmony is not controlling your devices
2. Completely cover the screen of your television with a blanket or dark colored sheet
3. Try changing the channel. If the device now responds, the television is interfering with your devices. Please contact Samsung for support
It is possible that by disabling certain features on your TV can also resolve the issue. Features that may cause interference with your remote include:
1. DNR/Active Control
2. Power Saving Mode
To disable either of these features, please consult the user manual for your TV.
SOURCE: We have a Harmony 550 universal remote the
Harmony remotes do no use codes. All you need to do to program your remote, is download the software and enter in the manufacturer and model number of you devices.
You can download the software from http://logitech.com/myharmony and click on "Downloads."
SOURCE: When I select view tv activity on my Harmony One,
It not the remote.The tv have problems,with it power supply board,it have a problems,it not giving ur tv the right voltages anymore,that why it take a long time,the tv to turn on.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
