Question about GE Washing Machines
I have GE washer-Model # WPSR3120WOWW. This washer is leaking some where. I know it is not leaking from water pump, Hose drain inlet or hose drain ASM. Help
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
Bgillespie
  • 89 Answers
SOURCE: How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Posted on Dec 15, 2007
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
  • 196 Answers
SOURCE: My GE WCSE4160B2WW top load washer is leaking.
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker
thanks.
Posted on Nov 05, 2008
  • 105 Answers
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Posted on Aug 02, 2009
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
see this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
Washer leaks when in use,in rinse ..
see this causes and diagram. God bless you
Water Inlet Valve
Drain Pump
Tub Seal
Sep 30, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer leaking
Water Inlet Valve
Drain Pump
Tub Seal
Sep 25, 2012 | Washing Machines
MY front load washer is leaking from under the washer. I have tried doing the monthly cleaning as it states in manual but this has done nothing.
There are several possibilities--the rubber seal between the cabinet doorway and the outer drum may be pulling loose or is punctured in some way. If the cabinet has a removable lower panel on the front, take it off and inspect the pump, the water hose from the drum to the pump, and the drain hose that runs from the pump out the back to the house drain for any possible leaks. If the leak occurs when the tub is filling with water, the hose that runs from the water inlet solenoids to the tub may be split or pulling loose. Open the cabinet top to check this. Hope this helps!
Jan 06, 2011 | GE Washing Machines
Every time we wash there is water leaking, not sure were the water is coming from. i have checked the hose.
Hi.
Check that the leak is not coming from inlet valve itself. If the leak is from underneath the washer check drain pump hoses. You may need to disassemble the washer pulling up the top panel and accessing the drain pump at the bottom to find the leak.
Dec 05, 2010 | GE Profile WPRE6100G Top Load Washer
I found a some water on the floor by the front of the washer. where did it come from ?
Most likey a water inlet hose is loose on the valve body or the water valve from the wall may be leaking or if thats not it then mostlikey te drain hose has a leak or the water pump may be leaking.
Apr 10, 2010 | GE WBSR3140DW Top Load Washer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Kenmore washer will not drain
Your washer does not have a cap on the drain pump. You need to remove the large rubber inlet hose from the front of the drain pump in order to access the pump impeller. This model washer tends collect debris in the large inlet hose area, so check it as well.
NOTE: If you own a wet/dry shop vac it will come in very handy to drain any residual water inside the wash tub. There's about a gallon of water that can remain in the wash tub and drain hose lines (this is normal). If you pull the drain hose from the standpipe at the wall and pull a vacuum on it with a shop vac, this will make clean up much easier. Otherwise, you will need some towels to lay down under the pump before you remove the inlet hose.
For an illustration of what I'm talking about, you can go to searspartsdirect.com and type in your model number. Look under the "Motor/Tub" heading for item 35 (drain pump) and item 41 (Inlet drain hose).
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Jul 14, 2009 | Kenmore Elite 45986 Front Load Washer
TOP LOADING WASHER leaking water
Check the pump and the inlet valves. The pump is located behind the drain line, and the two inlet valves are located in behind the knobs up top and can be removed by removing two screws up top and then removing the screws on the back side
Feb 10, 2009 | GE WBSR3140DW Top Load Washer
Our GE Profile Deluxe washer is not draining
Your post says "drain hose is kinked". I assume you meant NOT kinked. You didn't leave a model # so it's difficult to advise. If it's a top loader set it to spin and listen for the drain pump sound. If you hear just a dull hum it's probably stuck with something in it.
Use a shop vac to get the water out. Pull the front off and remove the hoses from the pump. Look into the inlet and you'll see the object.
Jan 06, 2008 | Washing Machines
Washing Machines Logo
142 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
