Question about Invacare Pronto M51 Power Wheelchair
My wheelchair dose not move
My wheelchair Pronto M51 dose not move, the joystick turn on, but nothing happens, I can ear the engine, bur dose not run plis hepl me\r\nraicesmayas@comcas.net
  • 175 Answers
The chair has two levers, one for each motor, that disengage it for freewheeling, or pushing the chair without power. These take it out of gear. Place the levers in the locked, gear-engaged position and it should go for you. Here's a link for the manual for your chair, and it will show you where the location is to place it in gear.http://www.invacare.com/doc_files/1125085J.pdf
Posted on Jul 12, 2009
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
When operating the Pronto M51 power wheelchair with the joystick, it will only move forward and backward. It will not turn. What do you think the problem is?
I would suggest that the micro switches that the joy stick operate have become faulty or got out of adjustment. contact the makers service agent to fix the problem
Sep 23, 2013 | Invacare Pronto M51 Power Wheelchair
Pronto M51 was plugged in and was turned on to use. The chair never moved and their were sparks from the joystick. Now the chair will not work. What can i do to fix this problem?
Power chairs are not designed to operate while they are plugged into the charger, as it will drag the charger around or you may run over the cord, therefore most power chairs have an inhibit feature that prevents the power chair from moving while it is connected to the charger.
If you saw sparks from the joystick, something has shorted out the controller; moisture or condensation may have gotten into the controller or there may have been a manufacturing defect.
I do not think there is anything you can do at this point except to contact the manufacturer or the place where you purchased the power chair to arrange a service call and replacement of the joystick/controller. If your insurance bought the power chair for you they may cover the repair if it is not covered by the warranty.
Dec 19, 2010 | Invacare Pronto M51 Power Wheelchair
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
The charge indicator lights flash left to right..when moving joystick the chair does not move.
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
The electric wheelchair is flashing the locked symbol but we don't know how to unlock it so that it will work
Turn on chair, move joystick forward till it beeps, then all the way back till it beeps, and then let go of joystick, it should fire up.
May 20, 2010 | Invacare Pronto M51 Power Wheelchair
Control box on pronto m51 wheelchair don;t work
When you say "control box" I assume that you mean the joystick. If there is no power to the joystick be sure that the batteries are fully charged and be sure that they do not need to be replaced, also be sure that the cables were not put on wrong. If all that checks out then be sure that all the cables are tight.
If all these do not solve the problem then you need to have the joystick tested.
Oct 17, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
412 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
