Question about Estate TEDX640JQ Electric Dryer
Estate dryer My dryer has heat but the inside will not turn. I read that it could be either a motor or belt problem. However, I don't know how to take the panel off the front part of my dryer. Please help the pile of clothes is getting larger by the minute.
    Scholar:
  • 136 Answers
Usually there are no screws, There are two large clips located inbetween the top and bottom of the unit where the crack is. All ya gotta do is take a large common screwdriver and pry around the two front corners. Yes it is hard and tough but it holds the top on. Give that a whirl and let me know :-)
Posted on Sep 15, 2007
Dryer will run and heat but will not turn
It sounds like your drive belt might be broken you can get a new one if you go to www.repairclinic.com enter in your model number and it should cost around 9$ the other possibility is the tension pulley or if it doesn't sound like your motor is running but most likely the drive belt .
Nov 24, 2012 | Estate by Whirlpool EED4400WQ Estate 29in...
Where should i look for the belt location inside the drier? the drier has heat, its making nois as a motor is ok but do not rotate anymore
If you need to find parts or manuals for the dryer, go to Google website and type in you model number and then type in what you need manuals or parts. More then likely your belt came off the idler pulley.
May 11, 2011 | Estate TEDS840JQ Electric Dryer
Dryer making noises from control switch heating up but not turning belt is ok makes noises from switch even in off position
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Estate TEDX640JQ Electric Dryer
My Whirlpool Gas Dryer Estate Model # TGDS680BW1 will not tumble when I turn it on but the motor still runs. How can I fix it?
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 17, 2010 | Estate Dryers
Dryer heats for about 10 seconds then heating element shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 12, 2010 | Estate TEDX640JQ Electric Dryer
Bosch wta 2000 dryer, heats but drum not turning
If you can hear the motor running then the belt has came off or it is broken. If you cant hear the motor then you possibly have a bad motor.
Mar 08, 2010 | Dryers
I have a Estate Whirlpool model#TGD5740. Smells like smoke when running. Still drys with heat and runs fine. What would cause this
You could have a build up of lent inside the dryer which might have ignited. Dryer should be dissasembled and cleaned.
Could be that your motor is over heating.
Depends on what type of smell your smelling;.If its the motor over heating, motor would have to be replaced.
Dec 27, 2009 | Estate EED4300SQ Dryer
Dryer wont turn but it will heat up
Do you hear the motor running. If you do then the belt is broken. If you dont then you have an issue with either the centrifical switch on the motor or the motor itself
May 27, 2009 | Estate TEDS840JQ Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Estate dryer electric, heating element gets hot but motor does
shut off power to dryer. take front off dryer,remove belt from motor and idler pully (if there is one) try turning the motor shaft by hand. if it doesn't turn ,take off back of dryer and remove blower housing and see if anything is blocking the impellers.. if not any of these then you may have to get professional help it may be a bad motor or timer
Jan 22, 2009 | Estate EED4300SQ Dryer
Estate TEDX640JQ Electric Dryer Logo
80 people viewed this question
Top Estate Dryers Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Mike
Are you an Estate Dryer Expert? Answer questions, earn points and help others
