MacG4+Reason+Umx25 Behringer Hi, i have a mac G4, reason 4 and a usb controllor behringer umx25. The problem is that i cant record on reason, i reach to play, control all virtual knobs, etc, but no recording in reason sequencer some midi tracks. Ty for your help
  • 65 Answers
Your problem lies in Reasons, and you need to setup your audio to except audio from outside sources. This should correct the problem without interrupting your midi. Good Luck
Fehdi
Posted on Aug 19, 2009
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
No blue light on Behringer Guitar Link UCG102
I have the same interface and also the light is orange rather than blue. Check this article where I quote:
"This (USB) light will be blue on older models of this unit and orange on newer models of this unit."
Setting up the UCG102 on Mac
Jan 13, 2014 | Behringer Ucg102 Guitar To USB Interface
I puchased a Behringer EPX2000 and I am not getting much volume out of it.
As you can see in these pics ,
http://www.avsforum.com/t/1236585/inside-pics-of-behringer-epx2000
, this is not a simple unit to troubleshoot. I need to know more about how you are using it, it needs some sort of preamp system or mixer board to drive it. Behringer stuff is also something extremely hard to find parts for, they are custom made for Behringer. Most power amps are made to be driven because the line in signal is very low for that reason. Let me know a little more info and I can help you more.
Mar 29, 2013 | Behringer EPX 2000 EUROPOWER
Where can I find the entire circuit board for TRUTH B2031A
Unfortunately Behringer equipment is hard to get parts for generically. You may be able to order the whole amp from behringer but I doubt it. I have had lots of problems repairing them for that reason and I will no longer use any of their stuff. The IC's could be repaired but can't find any record or crossover to any of their output transistors. It appears they are custom made for Behringer. Sorry, I can't help any more than that.
Mar 28, 2013 | Behringer B2031a Truth Active Monitors
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
I have a Behringer Mic C-1U and its not powering up!
How to Operate a Behringer C-1U
The Behringer C-1U is a USB condenser mic for recording individual instruments. A condenser microphone is a mic that uses vibrations produced by sound to change the distance of internal plates that produce signal. Condenser mics typically require an extra change, known as phantom power, to operate. Since the C-1U is USB powered, phantom power is not needed. The Behringer C-1U has a frequency response that favors sounds around the 10KHz range. This heightens the clarity of recorded signals due to the microphone's treble boost.
Things You'll Need:
* Computer with USB 2.0 port
* USB cable
* Recording software
Instructions
Turn on the computer. When the operating system loads, connect the microphone.
Install any necessary drivers for the C-1U. This will happen automatically when the device is connected.
Select the Behringer C-1U as an input source in any desired audio software. In Windows, click the "Volume" icon in the task bar to open the mixer. Select the C-1U as the primary input. On Macs, use the "Audio/MIDI Setup" in the "System Preferences" menu to select the C-1U as the primary input
Note: make sure you activate the phantom power on the mic. That's the only way to power up the microphone.
Have a nice day.
Feb 25, 2011 | Behringer C1U Microphone
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Don't know how to record from cassette deck to computer
here is the link for Behringer
this is the user manaul for UCA202
this should help you find what you need.
http://www.behringerdownload.de/UCA202/UCA202_ENG_Rev_B.pdf
Nov 10, 2008 | Behringer (UCA202) Sound Card
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
