Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
Drm-2001g turn on says hello that all
Drm-2001g turns on with remote and with button but only says "hello" on the led display. will not respond to any inputs at all
  • Anonymous Apr 29, 2009
    Same here. Formatting a disk when it froze for many minutes. Unplugged unit, waited a minute, plugged it back in. Now just blinks 'Hello' and all buttons unresponsive. Dead machine at this point.
    Sergeant:
  • 226 Answers
If you are comfortable with electronics and using a DMM, you could remove the cover and check the voltage on the power supply. Likely you will find that a few capacitors on the power supply have leaked onto the board, or are bulging on the top. If you can replace them with equivalents, it may bring your machine back to life.
This unit runs extremely hot, and capacitors, electrolytic anyway, will dry out and fail. There is a 'gel' inside that just dries out. That is why the fan blows on the power supply in later models.
You might also have a failed hard drive. You can substitute a known good disk. Make sure the jumper settings are the same. If that is the problem, it will take a few minutes after you power on for the machine to finish setting up the disk.
tom
Posted on May 11, 2009
No audio on polaroid DRM-2001G
just unplug the power cable for few seconds
Oct 21, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Replacement remote needed for Polaroid DVDR DRM-2001G
You need to change the IR LED in the remote. I swapped in a new one from an old remote and it works great, no pointing and walking up to the unit with the remote.
Apr 08, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
DRM-2001G weak remote
The range problem with the remote can be fixed by replacing the LED in the remote with a Radio Shack 276-143. The LED is a lot stronger and now the remote works a lot better.
You may also find that the 'receiver' inside the cabinet is pointed at an angle instead of directly towards the 'window'. You can trim the rubber(?) to allow it to point correctly.
Apr 06, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Vertical flipping
I bet you put it into PAL mode, the European standard. I believe that you can reset to factory default using the menu and it should be okay. If you cannot read and navigate the menu tree, then I think that if you hold the power button on after you start up, it will reset itself. I have not checked the doc to make sure of the last.
You can also get display problems if you pick the Y/R/G component setting in the menu. It is designed for connecting to a high definition using 3 different cables, one for each color. It only supplies vertical on one of those cables, and the TV just doesn't know what to do without the vertical blank signal from 'somewhere'.
Again, a menu setting.
tom
Dec 05, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
I have no video after accidentally making video output changes
I had the same problem. Thought the unit was trashed. But the solution was so simple. There is a button on the remote PS/IS. Just press this button and the problem is solved.
Oct 21, 2007 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
186 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
