Question about Sanyo DS27930 27" TV
No more picture and sound
Tv was showing perfect picture now it's snow. No sound or picture and in the menu area aspect ratio is highlighted red. I've tried reset and it says no signal from the antanna. I don't have cable yet, but I did use the cable outlet in the wall to support the picture clarity.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Posted on Sep 23, 2007
SOURCE:
How do you make your picture format bigger in your Phillips tv?
If set does not have aspect ratio control selection then the picture is fixed and you cannot adjust it. But, if the set is a newer model which supports digital tv reception or cable there is nearly always an aspect control feature available on the remote or in the menu area.
Aug 13, 2014 | Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
My toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Aug 03, 2012 | Toshiba 40E210U 40 in. LCD TV
The screen on our 42"
  • Turn on your VIZIO HDTV. Press the orange button with the "VIZIO" logo, which looks like a letter "V" with a triangular wedge in the center. If there is no VIZIO logo button, press the "Menu" button. Press the "Right Arrow" button twice to highlight the "Setup" icon, which looks like a wrench.
  • 4
    Press the "Down Arrow" button three times to highlight the "Wide" menu item. Press the "Left Arrow" or "Right Arrow" buttons repeatedly until the correct aspect ratio is selected. "Normal" is for a standard definition 480i signal, which has a 3:4 aspect ratio. "Wide" is for high definition signals, and has a 16:9 aspect ratio. "Panoramic" stretches the outside of the image while keeping the center at the normal aspect ratio. "Zoom" enlarges the image on the screen. Press the "Last" button twice to close the VIZIO on-screen menu.
  • 5
    Watch the image on the screen of your VIZIO HDTV to ensure that the picture is at the right aspect ratio. If it still looks distorted, it's most likely because you chose the wrong aspect ratio setting, because your source device is set incorrectly or because you used the wrong connection method.
  • Feb 27, 2011 | Vizio VW42LF 42 in. LCD HDTV
    The aspect ratio of my TV is set to16:9, however on some channels, the picture is not full screen?
    That is probably due to the transmission or aspect ratio of a dvd etc and perfectly normal but annoying!
    Try setting your TV to automatic aspect ratio, if it has one.
    Happy New Year.
    Jan 01, 2011 | Televison & Video
    Ok, so I need help. My mother just bought a flatscreen tv from best buy and had it delivered today by the Geek Squad. However, the picture makes the people look fat and the sound is tin-like. She can't...
    The people look fat and stubby is due to trying to display pictures that were made for old TV 4:3 aspect ratio and you are now trying to fill in the TV screen that has 16:9 aspect ratio. The only way for you to see proper pictures is to set the aspect ratio to 4:3 mode or set it to automatic to let the TV select correct aspect ratio of the pictures, the bad part is that you will see black bars on the left and on the right of the pictures, see more details with regarding to the aspect ratio in the user manual.
    Learn more here also:
    http://hometheater.about.com/od/televisionbasics/a/aahdtvfaqs6a.htm
    http://reviews.cnet.com/16:9-widescreen-tv-aspect-ratio/
    Not sure about your sound problem.
    Dec 17, 2010 | Televison & Video
    Adjust resolution on lumix dmc-tz3
    Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
    Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
    LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
    I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
    Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
    My tv the picture is bigger than the tv screen
    it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
    Oct 20, 2008 | Akai PT4298HD Rear Projection Television
    Aspect ratio
    You may have a vertical circuit problem causing the picture to stretch out. This is called "over scan". You need to have a tech check it for you. Stargazer
    Apr 19, 2007 | Sanyo DS24425 24" TV
    Sanyo DS27930 27" TV Logo
    172 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
