Question about Echo Rapid Loader, Trimmer Head
What is the maximum diameter trimmer line that can be used with the echo rapid load head
  • 32 Answers
SOURCE: How can I remove Echo 230 SRM trimmer head?
on the head there is a u shape slot on the side. turn it until you can slide a small screw driver in it to lock the head. then loosen the nut on the bottom i do believe it is a left-handed
Posted on Jul 23, 2009
woobie dog
  • 1273 Answers
SOURCE: Echo trimmer with bump feed is not feeding
Sadly, they do wear out..... but sometimes they're just stuck. The line can refuse to feed if the line is caught on itself in the spool winding, or if the head is bad. Try this: remove the spool and clean it pretty good. Check that the line isn't caught on itself in the spool. Sometimes it just locks itself in between wraps, and you have to pull it out of the groove to get it to continue to feed. Give the inside of the spool a liberal dose of graphite powder. Put the spool back on with line. Bump it against the ground as much as you feel necessary to further distribute the graphite. Now, push the spool in as if to feed line, and pull on the line. It should feed a bit and stop. If it does, you're good to go. If not, replace the spool.
Best regards. Hope this was helpful to you, --W/D-- Please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
  • 87 Answers
SOURCE: need to replace the trimmer head cutting line.
Did you try pushing down hard and turning @ the same time? that should do it.
Posted on Oct 05, 2009
RonInFla
  • 86 Answers
SOURCE: just got new U Turn Trimmer head. It has line
push down and turn until it comes back up...now, on that spot that is all the way in, before it comes back up, pull up on it...got it ?? The release is located where the the spool is all the way down and getting the spool to "hang up" on that spot allows it to release...because it can't when running makes it a perfect location
Posted on Apr 18, 2010
  • 38 Answers
SOURCE: how to change to a rapid loader head on an echo
line up the hole on the collar that the trimmer head is installed against with the arrow or notch on the gear housing, insert a punch or the brass colored pin that most Echo pieces of equipment come included with, this will lock the head. now turn the head clock wise, IT IS LEFT HAND THREADED! so righty loosey lefty tightey. now install the rapid loader with the included washers and10mm gold colored lefthand thread nut
Posted on Jun 01, 2010
I have an Echo SRM 225 and the trimmer head just throws the line . After bumping it it will not cut the line with the knife on the guard -it just keeps slapping the guard and the knife until all of the...
You are winding the line in the wrong direction. It should be wound on the spool in the opposite direction of the spin of the head during operation.
Good Luck!
Aug 07, 2011 | Echo Rapid Loader, Trimmer Head
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
Jul 02, 2011 | Echo Rapid Loader, Trimmer Head
Line spins out from rapid loader and doesnt stay put. has happened with 3 units after using for a short period of time
I've been using these for years! It shouldn't happen after only a few uses! Make sure your line is at least 3/4 of an inch inside the trimmer head! If you have been doing that the teeth are clogged! Take it apart and use a triangular file to clean the teeth!
Jun 17, 2011 | Echo Rapid Loader, Trimmer Head
What is the kinds of background for the html?
The Echo rapid loader is quick and easy to use. You mount the rapid loader to your weed **** . After it is mounted all you do is insert the line that comes with it into the hole from the outside, push it in and it will lock automatically. When the line is done you just remove through the hole from the inside. Then re insert a new line.
Feb 19, 2011 | Echo Rapid Loader, Trimmer Head
How do you load the trimmer head... Lost the user manuel
Check out the manual (available under the technical documents section of the Echo webpage, or at http://www.echo-usa.com/documentation.asp?Model=SRM-210&lang=E )and it will tell you how to change it.
Jun 25, 2010 | Echo Rapid Loader, Trimmer Head
How to change to a rapid loader head on an echo
May 18, 2010 | Echo Rapid Loader, Trimmer Head
Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Rapid Loader clogged
We fixed it ourselves. We first removed the rapid loader head from the weed eater, then loosened both sets of screws on the top of the loader, enabling my husband to unjamb the little slide, retightened everything, reinstalled the head and it seems to work fine.
Aug 15, 2009 | Echo Rapid Loader, Trimmer Head
Echo Rapid Loader, Trimmer Head Logo
217 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
