Question about Westinghouse LTV-17v1 17 in. LCD Television
Loses electric The TV has been in the living room and worked fine. I recently moved it into my bedroom but it turns itself off when I turn on the hall light or the bathroom light (both located outside of the bedroom). I tried using a power strip/surge protector - same result. Any ideas?
Get a voltage meter and see if you have 110-120volts ac at the outlet. If the lights and/or a bathroom fan have any feedback they could lower the voltage to your TV and it may have a low voltage safety relay that turns off the TV when low voltage is present. This happens in older homes. If this home is older this little problem may be telling you that the wiring in your home is old and in need of replacement. You do not want a fire.
Posted on Jan 11, 2009
Suddenly i turn on tv and nothing. it states "no signal" I have a verizon box in bedroom DVR in living room works fine.
Hi Robert,
First make sure the verizon box is turned on. If it is on make sure your TV is on the correct source input. When you turn on the TV, a display will momentarily show you what input your TV is set to. Usually HDMI1 or COMP is used. Push the TVinput or TVsource button on your remote until the correct input is found.
Good Luck
May 08, 2016 | Televison & Video
Aerial Socket on LG TV ceased working
Most likely the TV has a burned out receiver board.
May 24, 2017 | LG Televison & Video
Hi there. When I use the source button, the s-video option doesn't appear anymore. But, the cable in my bedroom is working. Meaning, my cable is working. The tv is saying weak or no signal. It was...
Hi there
Are you watching it through a cable box in both rooms? If so, it may be that the box in your living room has packed up.
Hope this helps
TV_Doctor
Jan 03, 2011 | Televison & Video
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
No picture or sound on my tv when hooking up my av cables
Ok
switch the power switch on then wait til the red light comes on..
the push and hold the power button until you hear it beep it should reset itself and sync up! may take 5-10 times
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Westinghouse LTV-17v1 17 in. LCD Television Logo
100 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
