I have a 4GB memory card which is empty but every time i try to send songs or pictures to the phone it says the memory is full help me please
As 'Kellmanjaro" said previously make sure the Data Service option is selected for Bluetooth transfers(Settings-Connectivty-USB Connection-Data Service). Choose the Mass Storage option if you want to drag and drop files from you computer to your external memory. I've found that you have to move each file straight away to your external memory after you recieve it via bluetooth otherwise you get the 'Memory Full' message popping up very quickly again after recieving a couple of files (this applies to the phone memory getting full).Select the song/file you want to move, select Options-Move to-External Memory.
Hey dude, I know its a bit late (like 2 months late) but if you have stuck with it (like i did) and your a bit of a nerd (like i am) i will now tell you how to fix this problemo: OK here we go -Go the the main menu on your phone (by pressing the middle button or the menu button) -Go to "SETTINGS" -Go to "CONNECTIVITY" then "USB CONNECTION" -Change so the tick is next to "DATA SERVICE", this will allow you to send and recieve items via USB, if this doesnt work change the tick back to "MASS STORAGR" and it should work Anyway i hope i helped Cheers Kel
When you plug your phone into the computer by USB cable two different drives should pop up ( eg. drive F and drive G) try opening the second drive. this worked for me. i hopw it works for you too : )
This is a known issue with the phone. It will most likely have to be replaced but you can try repairing it. This is a manufacturer's defect.
My LG Rumor had the same problem. I posted a fix here:
http://www.sprintusers.com/forum/showthread.php?t=164016
Btw, if you havent moved photos you've taken with your phone to the MicroSD card, they're probably hogging up some of your phone memory as well.
Good luck.
it tells me its full, when it isnt.
websliders are supposed to be great
but there just faulty.
i have the same problem i have a web slider i just got a 2G memory card and im trying to use bletooth to send songs to my phone and it says that my memory is full ??
