Question about LG 24 in. LDS 5811 Built-in Dishwasher
AE displayed on LG dishwasher - LG 24 in. LDS 5811 Built-in Dishwasher
  • 1 more comment
  • dscalderbank Apr 18, 2009
    Dishwasher starts cycle but 5 mins. in lights flash, bell rings rapidly and error OE is displayed - please help.
  • Douglaslappe
    Douglaslappe Jan 10, 2017
    The answer is wrong. My dishwasher has an AE code. The person who responded should take one more look.
  • Douglaslappe
    Forgot to add the code indicates too much soap suds. Unplug and wait 4 hours for unit to reset.
  • 423 Answers
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Posted on Apr 18, 2009
My dishwasher error code is AE what does it mean? I have tried to reset it but it still says that
If this is a LG dishwasher ... then the AE code means there is a leak somewhere underneath. On some models there is a small catch pan underneath that over time may accumulate some water which trips a sensor in the catch pan ... resulting in the AE code.
If that is your problem ... then resetting will not solve the problem since the water has not gone away. You need to take the front toe plate off and remove the water from the catch pan ... usually a paper towel can which it up as shown in the attached link.
AE Error LG Dishwasher LDF5545
You should also check all connections for leaks since over time the catch pan may fill again. Use a dry paper towel and touch all the connections ... if it becomes damp then you have a leak. (It is hard to just visually inspect for leaks)
Helpful?
Good luck on your troubleshooting!
Mar 03, 2018 | Dishwashers
I have AE error code LG dishwasher mode# LDF7774ST
http://www.lg.com/us/support/product-help/CT10000009-20150140938312-other-error-codes
Jan 13, 2018 | LG Dishwashers
Lg AE code
The AE error is
indicative that there is a leak
somewhere in the washer and it has
triggered the flood protection device
found at the bottom of machine.
For more information check the LG site: http://www.lg.com/ae/support/product-help/CT20076045-1442052868665-other-error-codes
All the best and Happy new year !
Dec 29, 2017 | LG Washing Machines
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
My lg washer/steamer wd14756sd has the ae code on display. what does this mean?
Code AE is a water leak. There is a float sensor in the base of the machine for this. The likely fault is the lower bellows drain hose as they are convoluted and this catches women's hair pins...the machine vibrations and water in turn rust these which pierce the hose. Hose bellows part number for LG WD14756SD is 4738ER1008A. Be careful for other machines the numbers/parts differ.
Unfortunately it's tight room to replace the hose but it can be done.
Jan 16, 2011 | LG Washing Machines
Ae display warning
Hi
Error AE means that the machine has detected a leak in the base of the washer. The anti flood device has detected the water and its displaying the error AE.
Unplug the washer and remove the back panel of the washer. Check for any stagnant water present in the base of the washer. If no water is present then check for the anti flood sensor and any disconnected wires.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | LG WM-12120BD Front Load All-in-One Washer...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
2,166 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
