Question about Toshiba Satellite M35X-S149 PC Notebook
Toshiba M35X-S149 laptop, lose video on boot-up.
I have a Toshiba M35X-S149 laptop and on boot-up I have no display. The screen is lit but black. After about 20 - 25 seconds the screen, still having no display, turns off. I can see it go black (not lit). The computer appears to continue the boot process as the hard drive continues to work.
I tried a desktop monitor, connected to the laptop, and at boot-up I have a small green indicator light on the monitor and I get the Windows XP screen. After about 20 - 25 seconds the screen goes black and the small indicator light turns amber. It appears I lose the video signal. Again, the boot process appears to continue as the hard drive is working. Any ideas what might be happening or what the fix might be? Thanks, Ray
Please note; I just re-soldered the "Maxum Max1532a Power Driver Chip" on the motherboard. Before I did this the laptop would not boot at all (On each attempt to power up, the laptop either does nothing, or the fan spins up, LEDs blink and then everything shuts down). If it were a bad solder - could it be interfearing with the video signal after 20 - 25 seconds? The fix can be found with site for details at; imateski.blogspot.com/2008/08/toshiba-satellite-m35x-motherboard.html
My Toshiba satellite M35X-S149 shows the lights and can hear it running but there is no display on the computer monitor
Hi oysertails...
Try hooking your laptop up to an external monitor...if you can see the picture on the external monitor then your lcd screen may need replacement or the lcd inverter board.
Please take time to rate me
Sep 24, 2011 | Toshiba Satellite M35X-S149 Notebook
Hello, When i turn my computer on the screen clearly turns on however there is nothing on it. It is just black but that sort of off black that is lit up. It makes some sounds as if it is doing something...
Hello !
Connect an external monitor and if it works, your problem is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Oct 28, 2010 | Toshiba Satellite M35X-S149 Notebook
My screen is black on my toshiba satellite m35x-s149 laptop. What do i need to repair this? I currently use a desktop monitor to see but would like to fix and use the laptop as it should be use. Any...
If you are getting display in an external monitor, it means Laptop is working fine except LCD. Better to replace the LCD. It will not coat you much. Contact Service center or Computer accessories dealer, for used LCD, they used to have from old PC.
Aug 20, 2010 | Toshiba Satellite M35X-S149 Notebook
I have no display on the screen. Its black.
This issue is usually of of 3 things...
1) the internal cable has come loose on the LCD inverter or motherboard
(need to open the laptop up by a trained tech)
2) Backlight buld is bad (look at the screen in bright lighting... can you see the image of the windows desktop there but very dark?)
3) Bad motherboard (must be replaced)
best of luck,
Sagacious1
Aug 07, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba Sate. M35X-S19 - Blank Display
It is more than likely that it is the display that is the problem.
And your original problem may have been the display and not the motherboard.
Please rate this if you find it helpful.
Thanks
May 05, 2009 | Toshiba Satellite M35X-S149 PC Notebook
NO DISPLAY ON TOSHIBA M35X-S149 LAPTOP
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 29, 2009 | Toshiba Satellite M35X-S149 Notebook
Clarify the problem of blank screen
sounds like the display/cable or the port on the systemboard failed. please call toshiba support http://www.toshiba.com/tai/support/support_cons.jsp
Mar 20, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
M35X Screen went black and will not come back on after shut down, reset and power up
Try to connect to external monitor and see if you see anything. Of course when you do that you have to hold at the same time fn key and the key that has a blue picture of computer screen.
Jan 17, 2008 | Toshiba Satellite M35X-S149 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Toshiba Satellite M35X-S149 PC Notebook Logo
288 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
