Dryer (gas) not heating any longer. Help! Gas line seems to be fine.
Maytag ensigna dryer not wanting to heat. Gas dryer that suddenly stopped working. Gas lines seem to be working properly
    Champion:
  • 219 Answers
Check your ignitor
Posted on Apr 17, 2009
Dryer was working fine. It's between 5 and 10 years old. Suddenly stopped heating. Model #HYG3658AWW Rev 14
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 06, 2011 | Maytag HYG3658AW Gas Dryer
Maytag gas dryer. Heating element comes on however, not every time does the gas click on so I get heat. Gas line is fine. What causes the click that gets you heat for dryer?
That would be the "igniter" you hear. You may have a problem with the igniter or the 2 coils on the gas valve. Below are links to the parts.
Igniter
Coils
Nov 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Our Neptune gas dryer seems to work fine but suddenly produces no heat. The vent is clear and the gas line attached and open.
Look at the glow ignitor. If it is broken then it needs to be replaced. About 20 dollars, and a 5/16 wrench will fix this issue, just make sure that you unplug the dryer before you start touching the electrical. This piece is located in the bottom of the dryer behind the back panel.
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Using a Maytag Ensigna gas dryer. Worked fine until tonight. Dry rolls, blower works, but pilot does not light so there is no heat.
sounds like the electronic igniter is not working ...I suggest you contact a gas appliance repairman and get it checked.You do not want to fool with any gas appliance
Dec 18, 2009 | Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Neptune Drying Center MCGAWW (No Heat)
Sorry no pilot light but you have ignite, flame sensor and a gas valve...all control heat...
let me know if I can help
krazytech
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
