Question about Dell Dimension 2300 PC Desktop
I have a dell dimension 2300 that turns on, but the power light won't light up and the screen is blank.Is it a motherboard problem or power supply problem.
    Scholar:
  • 44 Answers
I've run into the problem several times and it can be both.Your best bet would be to try the power supply first, being the cheaper and easier of the two. If you have another desktop you could try swapping the power supplies to test (make note of which plug goes where, it's fairly simple as long as you pay attention).
If you don't have a spare then it's possible a local tech store would have one you can purchase or pay them a small fee to test for you.
If swapping them doesn't work then it points at the motherboard.
Hope this helps :)
Posted on Apr 16, 2009
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
Amber light is flashing on my computer and it won't turn on at all. Help!
The Dell Dimension 300 gets the amber blinking light when there is power to the computer (the power supply) but the motherboard isn't getting the correct power. Sometimes it can indicate a motherboard fault or that the power supply is not set to the correct incoming voltage.
Check the back of the computer. If the power supply has a switch for incoming voltage, make sure that it matches your incoming voltage. Next check that the main power cable (20 or 24 pins depending on the computer) is fully seated on the motherboard. (It can only be connected one way and should lock onto the connector on the motherboard.)
Next check that the power supply is providing the correct power. You can simply install another power supply (known to work on another computer). Make sure that the PSU is correctly sized for the computer components. Alternatively use a multimeter or a dedicated power supply tester or put it in a different machine.
If the problem is not cured with a new PSU, the motherboard has a failure. Unfortunately, it's difficult to identify the exact bad component. (If a major component other than the CPU on the motherboard had failed, the diagnostic lights or beep codes could help identify the issue.)
I hope this helps.
Jun 10, 2012 | Dell Dimension 3000 PC Desktop
Installed new dell motherboard per tech, installed new Dell power supply as it died too. This is a Dell Dimension 2300. It won't start.
Check all connections, to the motherboard, and also to the wall Verify that the power supply is actually switched into the ON position at the rear of the computer.
Mar 09, 2010 | Dell Dimension 2300 PC Desktop
My dell dimension 2300 powers on,but nothing shows on the screen and i just got a brand new power supply for it.Also when i turn it on the power light isn't lit and it sometimes works.
Could you please post back with the status of four lights at the back of the system title ABCD. Also does the system shows the dell logo on the screen as and when the power light comes on.
Try removing the memory and disconnect the HDD and the optical drives from the motherboard and then power on the system. If the system comes on reseat all the above components one by one.
Thank You for using Fixya
Proton
Jul 12, 2009 | Computers & Internet
Dimension 4550 CN 02U819 power supply works but
many dells take proprietary power supplies. if you are using an aftermarket power supply, then you may have burned out your mobo. irregardless, your mobo may be dead, and that mey be the very problem.
Jun 08, 2009 | Dell (E210882) Motherboard
GRAY SCREEN
go to this link for help on th codes. You might have the wrong type of memory or the memory could be bad or maybe it's not seated properly.
http://support.dell.com/support/edocs/systems/dim2300/advanced.htm
Apr 08, 2009 | Dell Dimension 2300 PC Desktop
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
the motherboard is bad.
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 2300 - NO POWER
you will need to replace your power supply by the sounds of it, pending on your devices, a 450 to 500 watt power supply should do the trick.
Just make sure that you have the proper power connections on it like the IDE connectors or sata
Jan 23, 2009 | Dell Dimension 2300 PC Desktop
COULD THIS BE A POWER SUPPLY PROBLEM?
Call Dell and tell them, It sounds like it could be a power supply issue, however it could also be a bad motherboard as well.
Jan 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blank screen - won't boot!
iv had this problem , you'll have to put the correct disc for the comptuer and start over again :) otherwise you mite aswell just throw your comptuer out.
Dec 17, 2007 | Dell Dimension 2300 PC Desktop
Dell Dimension 2300 PC Desktop Logo
82 people viewed this question
Alun Cox
