Tv channels I have a samsung model #TTB1320 that I have not used in a while. I have cable t.v. but the t.v. is not going past channel 13. Is this not a cable ready t.v.?
  • Anonymous Jul 04, 2008
    Help
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Call technician he will suggest you to install converter or replace tuner accordingly.
Posted on Sep 17, 2007
SOURCE:
Channels only go up to 14 then bluscreen after that, i have basic cable that should got to channel 64, i am using universal remote so i have to fix from tv
Check antenna cable setting in menu. If you have it on antenna and cable plugged in, you will not pick up anything past channel 13. Change it to cable setting in menu.
Nov 27, 2011 | Prima CV2011 TV
Use to be able to get all channels now can't get any channel past 19
check the menus channel setup and make sure you are in cable mode and not tv mode, put the tv in cable mode and do a channel search.
Jan 23, 2011 | Zenith SY1324S 13" TV
I moved tv now it want go past channel 13
No problem. Go into menu to channel or tuner setup.. When it was unplugged the tuner reset to air and needs to be changed to cable and then auto program the channels..
Oct 17, 2010 | Panasonic CT-27D12D 27" TV
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
I can only see 13 channels... why is that ?
If you have your TV connected directly to a cable system without a converter box, be sure the TV is set for "cable" or "CATV" tuning. You'll probably find it's now set for "air" or "antenna" mode. In that case, you'll only get 13 channels. Channels 14 and up won't be found. Switch tuning modes, let the set scan channels and you should have the full selection.
Hope this has helped. Thanks for using Fixya!
Feb 20, 2010 | Samsung SlimFit TX-T2782 HDTV
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
TV WONT GO PAST CHANNEL 13
Go into your channel setup menu and make sure you selected "cable" and not "air". After selecting "cable", autoprogram the tv
Dec 06, 2008 | Televison & Video
Channel problem
Try going into the menu and changing it to the cable setting.
Sep 27, 2008 | Toshiba MV20FL4 20 in. TV/VCR Combo
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Ekse
