Question about HP DeskJet 680c InkJet Printer
Printer problem need help with hp deskjet 820cse does not print put in new ink and the little light is on that looks like an ink drop
  • 62 Answers
Hi, after you install a new ink cartridge you need to run the printer software to add the new ink levels. Have you done this?
Posted on Sep 15, 2007
SOURCE:
The color yellow does not print., both color and blk ink cartriges are new
Make sure the color nozzels are clean, sometimes the get clogged.
May 29, 2010 | HP DeskJet 820Cse Printer
My printer had a paper jam and when I removed the paper it no longer prints. The paper feeds through but the ink cartridges make a slamming sound and nothing prints.
Dear friend ,
There is More thing to be explain in Detail. So Check out this Link You will be Solved...
If this Helped you,Do RATE ME..Thanks For Using FixYa....
Apr 22, 2010 | HP DeskJet 820Cse Printer
I have just replaced the color ink cartdrige in my HP Deskjet 722c printer and I tried to print a color picture in bond paper and it was a total mess
A new ink needs a little cleaning before using. Just dab lightly on a damp paper towel and look for a inch log stripe of each color on the towel. If all colors are not there it won't print very well and you should return the cartridge. Some have reported no yellow in their new cartridges.
Jan 08, 2010 | HP DeskJet 722c InkJet Printer
HP printer , will not print
aasc - As I recall from some time ago, HP experimented with putting expiration codes (chips) into some of their printer cartridges in an attempt to counter the print cartridge remanufacturers. These "refillers" were starting to really eat into the sales of new HP printer cartridges.
This was first done with some of the printers in the late 90's and I know the 800 series of printers had this "feature." You can either try a reset procedure, which is a pain and documented on various web sites:
http://www.youtube.com/watch?v=zVR2dHebmTI
The other issue could be a full printer ink reservoir (some call it a spitoon) or a clogged print head. Try running the printer cleaning operation from the HP printer utility in your PC Control panel to get the heads clean, etc. The other part about cleaning out the excess ink reservoir is a little messy, but here's a link that covers that too, for your printer.
http://www.fixyourownprinter.com/forums/inkjet/12839
The other thing to try, if those about don't get you running again, is to try swapping two (2) new cartridges into the printer and then swap back the refilled ones in at attempt to "trick" the printer into thinking you've got all new virgin cartridges in it. Unplug the printer and install the new ones and turn it back on. Once you've got the printer working, you can try swapping in the refilled ones without turning off the printer, just life the cover on the printer and the cartridges will slide to the center for removal/replacement.
I had this happen with my 895cse and after researching it further, discovered that yes HP was doing this to prevent other companies from eating into their very lucrative printer/toner/ink sales, which is really where they make their money from. (sorta like razors and razor blades, they'll give you a free razor and make all their money/profit on the blades as the comsumable item)
Another option to try is to reset your system clock on the PC to a date about a year previous from today so the print cartridge memory chip thinks the cartridges aren't that old - this was a suggestion from a tech kid at best buy when I was having this same issue a couple of years ago.
Anyway, I've been using the refilled inks most of the time and opt for a new set for every third set, just so I've got a good set to refill.
Hope you find this Very Helpful and best regards!
Oct 09, 2009 | HP DeskJet 820Cse Printer
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
Does not print
get a new cartrige
Feb 11, 2009 | HP DeskJet 820Cse Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
HP DeskJet 820Cse
That's because the driver doesn't tell you the ink is low. The software does. The software doesn't come with the os just the driver. Do you have a cd for Win XP? I'll get you the link to download the software just in case.
Apr 15, 2008 | HP DeskJet 820Cse Printer
Print alignment
hi, the printer has rubber rollers which pulls the paper in during printing, it seems like one side of the intake pully does not have enough presure or the rubber has hardned or worn out, hence it is slipping off,check that area , let me know.
Dec 16, 2007 | HP DeskJet 820Cse Printer
HP DeskJet 680c InkJet Printer Logo
89 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
