Question about Motorola Mobility RAZR V3
White Screen Fix
Do you know how to fix the white screen on the razr
    Brigadier General:
  • 7,752 Answers
Yes i do, have the flexcable replaced and this would correct the issue.
Posted on Feb 18, 2008
SOURCE:
How do you fix the white screen on a motorola razr? I have tried to reset the battery and reboot the device, however, all i get is a white screen screen. The phone works find, just now display (very weak...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 11, 2010 | Motorola Mobility RAZR V3
My razr keeps going to a white screen. fix??
to make it sure bring your mobile to a service center i think you have a problem in your screen.
thanks,
Jun 03, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Screen won't turn off. Goes white
Have you tried turning your phone off and removing the battery.
leave your phone off for like 15-20 mins.
then replace your battery and wait 15 seconds before you turn it back on it should help you.
May 29, 2009 | Motorola Mobility RAZR V3
Razr motorola cell phone, screen turns white
yo i had the same prob but it is easy to fix. do you see the joint where the fone flips and there is a bar in the middle going straight down turn that right like righty tighty and restart phone be carefull cuz the bar is plastic so it might break off if you use pliars hope i helped!
Mar 29, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola razr V3m cellphone has a white screen
Unfortunately you are going to have to change your screen. The following link is a step by step with pictures and explanation on how to do it.
Please remember to rate me.
Feb 02, 2009 | Polaroid I533P Digital Camera
RAZR V3 Screen flashes black and white
the firmware needs to be flash into teh phone take the phone to a mobile service center and have it fix.
Nov 25, 2008 | Motorola Mobility RAZR V3
White screen
The next time your driving down the road and this happens increase your speed to around 70 mph role your window down check the display to make sure it hasn't rebooted, then fling it at the next roadsign if it doen't cut through the sign and fix its self sue motorola's **** *** for false advertisment!!!**** them
May 23, 2008 | Motorola Mobility RAZR V3
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Blank screen
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Switches on then nothing
i think you screen is jammed.send to fix shop
Jun 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
