Question about Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Dvd player will not play dvd
Upon loading a dvd, it makes noises like it is about to start and then makes the same sound again over and over. no picture from the movie ever plays. the screen stays blue.
  • Sylvania Master
  • 5,660 Answers
I don't know the age of this DVD drive, nor how often it has been used, but the drive may be at the end of it's 'Life Cycle'. All mechanical devices for a computer have a rating of so may hours of usage.
It could be just something simple though. It may be that the optical eye inside your DVD drive is just dirty, and cannot read DVD's anymore. My solution for this, is to just buy a can of compressed air for computers, and blow the inside of the DVD drive out.
Computer on, open the tray for the DVD drive. Now shut the computer off normally. The dvd drive tray should stay open. Unplug the computer from the surge protector.
Break the plastic lock tab, off of the top of the can of air. This lock tab is put there to prevent depressing the trigger during shipping.
Insert the plastic 'straw' provided with the can of air, into the nozzle.
Try to hold the can of air in a vertical position, as you are using it. (Do Not shake the can) This is not always possible, and it is my contention, that if you are doing a good job, inevitably you will tilt the can along the way. You may see what looks like moisture, coming out of the can if you tilt it. This is okay!
What you are seeing is the propellant for the can of air. The stuff that pushes the air out of the can.
You can stick the straw into your DVD drive opening. Depth is up to you. I advise aiming at the top/backside, and spray your way towards the front. Start from either the left or right side, and go across. Make rows as you move towards the front.
Now go towards the bottom side. This side is your most concern. The optical eye is located on the bottom. You won't be able to view it though. Start at the back/bottom, and making rows again, work your way towards the front.
As you go along with the can of air, you may notice the pressure drops. This is because the air is coming out so fast, that the moisture in the outside air freezes. The straw and nozzle freezes up. You may notice frost on the outside top of the can.
Let the can of air sit for a few minutes. The can will warm up, and you'll be able to use it again.
When you are satisfied the inside of your DVD drive is clean, let the tray set open for a few minutes.
Ten minutes or so, should be okay Sometimes the frozen moisture, and/or propellant, will linger inside the drive. It should dry out within that ten minute span.
If you are satisfied that the inside of the DVD drive is dry, plug your computer back into the surge protector. Wait One minute. Turn the computer on.
Posted on Apr 16, 2009
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 14, 2012 | Sony Televison & Video
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
HP dvd play on my laptop malfunctioning
grinding sounds is from the dvd drive itself. Sounds like its not sitting properly in the drive or the holder that it sits in is going bad. Either way replace the drive and that will take care of the grinding sounds. Also the more grinding sounds that happen, the more of a chance you take on your dvds getting scratches on them and going bad eventually.
Jun 11, 2009 | Compaq Presario Notebook
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
Dvd won't load
open it and check for a broken part in one of the gears that operate the drive. if the unit is under warranty, take it back rather than try to fix it.
either something is in the mechanical portion of the unit, or it is badly worn.
i would suspect a broken part from the noise issue/ clicking sounds.
the read head runs on a track and could be jammed up, unable to run to access the directory of the disc. inspect what you can get to, and hopefully that will be a simple fix.
good luck
mark
Jan 05, 2008 | Symphonic SD200E
Insignia portable dvd player
It sounds like the player needs to be cleaned. Just go to your local electronics store and get DVD player cleaning disk. They are only like $10 and do the trick. Whatever you do, DONT blow into the player as it will only make it worse.
Dec 31, 2007 | Televison & Video
DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Dec 13, 2007 | RCA 20F610TD TruFlat TV/DVD
How can i fix my portable dvd player?
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
Apr 26, 2006 | Durabrand 8.5'' Portable DVD Player
Sylvania 6720FDD 20 in. TV/VCR/DVD Combo Logo
73 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
