Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Take apart method to replace rubber drive belt.
I removed all the screws but I couldn't get the housing apart at the tip where the shaft comes out. I think the drive belt came off the motor and drive shaft. How do you separate the halves of the housing?
Larry larson1930@hawaiiantel.net
  • 1 more comment
  • Anonymous Apr 26, 2009
    I had the same problem. There is one screw that is hidden beneath a sticker towards the bottom. You can feel it through the thin material. Either cut a hole in the sticker or peel it back to reveal the screw hole. Chances are the plastic gear is melted and the belt is ruined from the melting plastic. This is what happened to me and many others with the same story on the internet. I haven't had it fixed yet, happened on the weekend. They need to replace the plastic gear with a aluminum one.
  • larson1930 May 15, 2009
    Alas the hidden screw under the label and the hog came apart. Guess they do not like customer repairs. The problem now is what do I do to repace the "melted" drive wheel. And where can I get a replacemnt and for how much?
    Thanks
    Larson1930
  • Anonymous May 20, 2009
    I too had the problem with the melted drive wheel and ruined belt. The fatal flaw is with the plastic wheel and worse, the plastic mounting for the wheel. When tension is applied by the tight belt, the flimsy plastic mount flexes and the gears are no longer parallel resulting in terminal friction. If you repair with identical parts, they will break again quickly. This grass hog(express) lasted for 3 uses. That is the most uses I have ever gotten from a grass hog. I have had two before this one. Will I ever learn ?.... Yes !
I had the same dillema, till I discovered a soft spot on the label. They put one last screw there. I got the housing open and discovered the belt was broken. Ordered a new belt ($12.39) through ACE Hardware repair center, now I can't get the belt on. That is why I came to this site.
The Ace guy told me he has had lot of calls for this particular belt. If you order one, I suggest you order two.
Good luck.
Posted on May 15, 2009
Want to replace traction wheel rubber
Unable to find that part number, however, the side truck skirts are mounted in two different ways. The first, the easiest, the two screws on each skirt are accessible directly from the bottom. The second is a pain. First remove the shell from the main drive by removing the self tapping screws. Once the shell is removed, remove the single screw that goes from the bottom of the truck to the motor shaft. With the engine removed the truck should fall away from the mount. You will find the 2 skirt screws now accessible at the top of the truck. Replace the belt(s) and reassemble. These screws are usually M3-05 X 5 or 6mm and are easy to lose, so be careful.
Mar 08, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
How do you replace the belt on xl2200 upright oreck vacuum cleanrer
Ok with the front of the vacuum facing you look on the left had side of the power head then follow these steps.
1.Remove the door by removing
the hold down screw located on
side of power head.
2.Slide the door forward by
prying open with a screwdriver
or coin.
3.Remove the belt from the brush
roll pulley and the motor drive
shaft.
4.Loop the new belt over the
motor drive shaft. Place the
opposite end of the belt on the
brush roll pulley.
5.Rotate the brush roll three (3)
complete revolutions to ensure
that no part of the belt is
overhanging the end of the
motor drive shaft.
6.Replace the door by sliding it
into the groove at the bottom of
the housing. Replace the hold
down screw.
Jun 22, 2011 | Vacuums
I need to remove my auger on my snow thrower, but I am not sure how to remove the auger bearings to allow the auger to come out.
There should be bolts to remove on each outer end of the auger shaft, and the blower shaft must be removed from the rear bearing/pulley at the rear of the blower housing. Look for bolts to release the entire blower housing from the engine/drive section. On out Sears unit, there is a nut on the end of the engine crankshaft that allows the two drive belts to be removed. If you don't have the service manual, be sure to make notes of each part as it comes off of the machine (there will be many). Check the condition of each belt and also the rear bearing that the blower shaft came out of. The gear box at the front end of the blower shaft must come apart to release the auger shaft. This is not a job for the faint of heart! Good luck!
Nov 28, 2010 | Husqvarna Garden
How to change the snuber ring on a Maytag MAV9750
To replace the snubber and brake assembly on your Maytag washer, just follow these steps:
1. Remove the front case of the washer to access the washer interior.
2. Tilt the washer towards the back and remove the drive belt. Slide the drive motor towards the center pulley to relieve belt tension.
3. Remove the drive pulley by removing the center cap and retaining ring from the drive shaft. Remember how these components go back together. There should be a couple of plastic drive bearing pieces and some metal washers above the pulley on the shaft.
3. Lower washer and remove hoses from the wash tub.
4. Remove the suspension springs. NOTE: Pulling the wash tub towards the spring you are removing will release some of the tension on it.
5. I usually remove the entire wash tub with transmission still installed at this point and place it upside down outside the washer for ease of accessing everything. (There are other methods, but I find this one easier).
6. This is where a brake compression tool will be required to remove the brake rotor, stator and snubber ring. (Instructions come with the tool). Basically, it involves compressing the spring by turning the compression tool CW with a wrench, loosening all the bolts on the brake stator housing, and then slowly turning the compression tool CCW.
7. The brake compression tool is removed at this point and the snubber, brake rotor, brake stator and brake spring can be accessed.
8. Replace any worn parts, and reassemble the brake assembly. DO NOT forget to place the brake spring back in place before putting the brake rotor back on.
9. Place the tub assembly right side up and lower back into washer.
10. Reconnect all hoses back to wash tub.
11. Reinstall all tub suspension springs. NOTE: It’s easier to start in the back of the washer and work your way towards the front.
12. Tilt washer back and reinstall drive pulley. NOTE: When placing drive pulley back on shaft turn pulley slightly to ensure it is seated all the way on the shaft. NOTE: If the shaft had multiple metal washers, you may only need ONE after replacing the snubber ring. Retain the extra washer for later use if needed. If the drive pulley is reinstalled correctly, a groove will be visible at the end of the drive shaft for the retaining ring to go back in place.
13. Reinstall drive belt.
NOTE: The following link lists the recommended tools to complete this repair:
Spring Removal Tool (item #455570)
Brake/Bearing/Seal Removal Tool Kit (item #997909)
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
However, I had a suggestion from someone I had helped in the past that provided this brilliant idea to save money instead of purchasing the brake release tool:
"I removed the 6 10-24 machine bolts, that hold the brake stator housing, one at a time and replaced them with 10-24 x 2" machine bolts. Once all the original bolts were removed, I backed out the 2" machine bolts evenly, keeping the brake stator housing aligned but slowly releasing the pressure from the 200 lb spring.
After replacing the snubber ring, the break and the break stator housing, I again use the 2" long machine screws to pull the unit together. Once all assembled, I replaced the 2" bolts with the original 10-24 X 1/2" machine bolts." Tip courtesy of rrdumas53.
If you have questions about this repair, please let me know. I hope you find these instructions helpful.
Sep 24, 2009 | Maytag Atlantis MAV9750A Top Load Washer
Trying to take the housing off my weed eater
I assume that you have all the screws loose and it still will not come apart. You will have to remove the screw which is up inside the square shaft drive on the clutch drum. After you get the drum off you will have to remove the clutch. It is threaded on the crankshaft.
after you get the clutch off the housing will come off.
Sep 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Check for a pair of screws at the outer edge of the brush housing area. On this unit I believe the unscrew form above. Then look for any others on the bottom plate below the the brush. Belts can break or burn thru. If your s has burned, clean the burned rubber from the motor shaft before replacing. Spin the brush roll, if it rolls smoothly remove it , place the belt over the motor shaft, then onto the brush and use the brush to pull into place.Check for hair and thread buildup at the end caps of the brush. The nylon caps pop off for cleaning.
Sep 06, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Replace belt on amana washing machine
Do you mean the water pump? If so, it's likely rusted on the shaft. I used a couple 15" screwdrivers as pry bars. Got it off, didn't break the pump, you might not be so lucky. Clean the shaft with scotchbrite, a dab of silicone lube will make it easier next time. If you have a camera take a couple pics BEFORE you take it all apart. The belt will fit 2 different ways, and one way will chew up the plastic pump support post. Don't ask how I know. (Took a lot of effort to get it off, but you have to in order to change the belt. A new pump, if needed, is about $20 around here.....)
Dec 06, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Replacing rubber drive coupling
My coupler was split in two, and I couldn't screw it off. I had to do the following:
1. Take the blender apart (mine had 2 screws on the bottom). 2. Remove the motor housing from the blender (mine was loose from removing the two screws earlier). 3. Remove the fan by removing the fan nut. 4. Take apart the motor housing. Mine had two machine screws with 1/4" hex heads holding a bracket that tied the two ends together. Once those two screws are removed, you can take the motor out of the housing. Be careful on the fan end of the motor, because it's got two spring loaded brushes that will come together once the motor is pulled through. 6. Once you have the motor out of the housing, you'll have something to grab onto so you'll be able to unscrew the broken coupler. I used a pair of channel locks and gently grasped the motor body, and then just used a regular pair of pliers to grab the broken coupler. It's regular thread (lefty lucy righty tighty), so twist accordingly.
Once you have the coupler off, just put everything back together. The hardest part is holding apart the spring loaded brushes while you push the fan end of the motor shaft back through the motor housing.
Took me about 20 minutes to do everything.
Good luck.
Nov 20, 2008 | Oster 4093-8 Osterizer Classic Blender...
Eureka model 4870 belt replacement
- NO WAY AROUND THE END OF THE DRIVE SHAFT TO REMOVE DAMAGED BELT.
  • Following the belt replacement instructions in the manual, I removed the three screws, took off the base plate and removed the brush roll, slipping it out of the belt.
  • Up and somewhat inside the plastic housing I could see the other end of belt going around the drive shaft.
  • But the shaft had no gap around its end to allow removal or replacement of belts. It extended from the motor completely across the space and against the plastic housing.
  • Yikes.
  • I dismantled the housing until the end of the shaft was accessible and found that the problem wasn't the shaft moving out of position.
  • The problem was that the bushing mounted on the end of the shaft for the belt to ride on had slipped over.
  • Ah HAH.
  • I applied some LokTite green threadlocking adhesive (though neither the shaft nor the bushing are threaded) to the shaft, slipped the bushing all the way onto it and put it all aside to set up.
  • Finally I reassembled the machine with a new belt in place, plugged it in, crossed my fingers and hit the power switch.
  • It worked like new! FIXT! And I had only one screw left over. It was a small one too, so I doubt if it was important...heh.
Does your machine have a slipped bushing? You may be able to fix it without taking it apart any more than for a normal belt replacement. Try using a rubber or plastic-tipped forceps or pliers move the bushing back into position. Be careful not to mar the metal as it will chew any new belt to bits in seconds. If you are able to move it, put on a few drops of LokTite, epoxy or some other adhesive to keep it in place. You may be able to avoid sending your vac to the shop for costly repairs.
Apr 29, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
1,238 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
