Question about Thermador SC302T Electric Double Oven
Hi.i have C302ZS thermador doble oven.The problem is when its heating for 25 min.Clock start beaping with no code.I replace new touch panel and relay board according the service manual but it did not help.Before i have code F24.I am kind of stock. Thanks
  • 1 more comment
  • mike840 Apr 16, 2009
    I am a tech!!! and did replace relay board
    Just F24. Thanks
  • 10,515 Answers
Hi mike 849,
 F24 refers to bad keyboard ( Touch pad ).....
You can order one at the Thermador website. They also offer express shipping with an extra charge of 25 bucks.
 If you wish you can call them at
714-890-4718
Thanks for using Fixya.
Posted on Apr 16, 2009
    Top Expert:
  • Thermador Master
  • 79,186 Answers
What is code F24.1?
    Scholar:
  • 123 Answers
Hi, According to the manual, this is an element relay circuit failure. Call the tech
Why do I have error code F25 on my Thermador oven error codes
clean the touchpad control panel. Make sure the oven door closes properly to prevent excessive heating of the touchpad. If these don't resolve it, it calls for a replacement of BOTH the touchpad AND the relay board. EXPENSIVE!
Aug 23, 2014 | Thermador SC272T Electric Double Oven
F21 error codes
shorted cancel key. replace touch panel and relay board.
Jan 30, 2014 | Thermador C302U Electric Double Oven
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
How to install air flow switch on thermadore c302zs
remove lower trim UNDER lower oven door. It's right there.
Dec 10, 2012 | Thermador C302U Electric Double Oven
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
May 20, 2011 | Thermador C301U Electric Single Oven
Thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Thermador C302U Electric Double Oven
FO shows on led board for both ovens
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the EOC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 06, 2009 | GE Profile JT952 Electric Double Oven
I have a Thermadore double wall oven, M# C302ZS. The oven is reading F24. I put in a new whole front touch pad, and it's still reading F24. What can be my problem??
I've copy and pasted an exert from this ovens service manual. try this and let me know of the results.
Good Luck
F-24 or F-25 This is caused by close contact to the control panel for more than 60 seconds,
appears in display window such as someone leaning against the controls or objects hanging in front of
controls.
F followed by 2 digits appears Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn
in the display window it back on.
Oct 29, 2009 | Toastmaster Ovens
I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Aug 17, 2009 | Thermador C302U Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
220 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
