FixYa.com
Tags:
Hard Drives
Generic problem for all Hard Drives
Laptop usb hard disk
posted by vivek2001 on Sep 15, 2007
I recently got a western digital laptop hard disk , used one, all pepped up in a usb case.It's been almost a week now and it was fine.just a couple of seconds back my comp acted weird so i shut it down.now after restarting it, my comp doesnt recognize the usb hard disk and there is a constant ticking noise coming from it accompanied with blipping of the led
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 17, 2007
Thanks for Trying (70)
dodgecharger
Rank:Wiz Wiz
Rating: 82%, 246 votes
This doesn't sound good. Strange clicking/ticking noises as described may well indicate the drive is bad.
Here is what I'd do: Take the USB drive case apart, check the interface cabling to the drive, and try it again. If it still doesn't work, try removing the drive and installing it in a desktop computer as a slave drive. I've only had one of these USB connected drive assemblies apart, but that one used a drive with a standard 40 position ribbon cable interface, the same as what is used on pre-SATA desktop systems.
If the drive still doesn't work, you can't access it, check your BIOS settings, etc. Problems still, download the Western Digital drive diagnostic softward and use it to check drive for errors.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 05, 2007
Not Rated (0)
bfqzgst
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Did this work? I have the same problem.
This Problem Also Relates To: Memorex Ultra Traveldrive - 160GB USB Hard Drive Acer (91.AB033.041) 73 GB Hard Drive Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive IBM (IBM60GB) 60 GB Hard Drive Fujitsu Siemens (MHV2060AH) 60 GB Hard Drive LaCie d2 Extreme with Triple Interface hard drive 250 G LaCie Design by F. A. Porsche 160 GB Hard Drive
Can you Help with these Hard Drives problems?
SanDisk 2GB Cruzer Micro USB Flash Drive...
Sandisk USB Cruzer cannot...
When I insrted the USB to... Answer This...
SimpleTech SimpleDrive 160 GB External USB...
Simple drive 160 gb
My simple drive was working... Answer This...
sandisck cruzre 2.0 GB
My name G. Lopez. Every time I... Answer This...
Excelstor Technology J880 Hard Drive
Cant install ubuntu 7.04 on...
I am new with ubuntu, but when... Answer This...
HP Pavilion ze5000 30 GB Hard Drive
hp ze5400 lp power problem
when i power on it shows the... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
