Question about Nintendo DS Lite Console
Top and bottom screens on ds not working but green light is on
I keep trying to turn my ds on but i keep getting the same thing over and over again
  • matteos Apr 18, 2009
    Same problem: top & bottom screens on ds not working but green light is on. Which wire is loose & how to identify the wire?
    Problem Solver:
  • 3 Answers
One of the wires on the inside is loose, I had this problem when I took apart my ds. You will need a Tri-Wing Screwdriver to get it opened up. Then you need to find the wire that is loose.
Posted on Apr 17, 2009
My ds lite won't turn on both fuses are good the top screen was broke so I tried another screen I had that dident work. So I put the old one back on and now the ds wont turn on .The green lite flashes then...
It's all to do with the top screen... What happens is that when you turn the DS lite on it performs a quick check on the screens to make sure they are connected properly, if one or both are not connected properly then the unit will shut down.
The flashing of the screen shows you that that particular screen is fine whereas the one that does nothing is not connected properly, either through a loose connection or faulty screen/ ribbon.
Your best bet is to buy a new top screen (I usually get mine from ebay for around £10-£12) and fit it. That should sort out your issue.
Any further problems or questions feel free to message me via my profile page.
Regards,
SOD69
Feb 22, 2010 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
DS lite screen
Hahahahaha that is how it works but if you go to the little DS at the bottom of the touch screen and tap it there will be a fixer manual use it and when you are done the system will shut off and just turn it on again and also the touch screen is the most important thing on your ds so keep it scratchless and clean! On some games the top screen is an important thing and somtimes it doesnt show anything
Mar 02, 2009 | Nintendo DS Lite Console
Ds broken? Green light blinks, bottom screen flashes, turns off.
You will have to open it up and desolder the fuse that says, F2, and then solder a small piece of wire onto the two spaces that the fuse sat on in order for you to bridge the fuse because it's probably blown. Then try powering it up. If it works, then you have just repaired it. If it doesn't then there must be another fuse that is blown. Try testing the fuses with a multi-meter. I am guessing that it could be the F1 fuse if the F2 fuse was also the culprit. Do the same thing to bridge the F1 fuse and then it should work.
Feb 25, 2009 | Nintendo DS Lite Console
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on
My kids did the same thing. What I did to get it to work was to push back on the top and hold it turn it on. If it comes on then turns off after you let it go get 2 rubber bands and put the 1st. one on the top left down to the bottom right. The 2nd. one goes from the top right right to the bottom left. Then keep turning it on while moving the top to find the sweet spot.
Jun 03, 2008 | Nintendo DS Lite Console
DS Powering On
Hi, if the bottom screen briefly comes on with a white screen. There is a issue with the top screen, it is either the top screen itself or if there is damage to the hinge it will more than likely be the cheaper option the ribbon cable that threads though the hinge to the top screens PCB board.
Mar 16, 2008 | Nintendo DS Console
ve you dropped it a few times or spilled water on it, if you have then thats the problem i sugeest that you try and get it fixed or if a friend whos an expert on this stuff
Hope this helps!!
p.s shake it if you hear a rattling noise then thats causing the problem
Dec 11, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
118 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
