My Brother MFC620 CN displays the ''no cartridge'' diagnostic or ?Black cartridge is empty ? even after I install a full new black ink cartridge. And the ink level readings on the color cartridges are displayed as low ( 1 square out of a possible 7 ) even with relatively new color cartridges. What?s the problem ? This unit is just getting more cranky with each passing month. It is 3 and 1/2 years old. I print about 1000 pages a year maximum. Is it time to junk this unit and buy another Multifunction unit ? What brand would you recommend ? Best regards, Phil J-R Anaheim, CA 92808 Phone & fax: 714.281.6127 Cell: 714.747.0163
    Genius:
  • 1,847 Answers
Hope you are using the original cartridge recommended for the printer.
Take the cartridge out and clean it with little alcohol and cotton. Clean both the cartridge head and the carrier. Reinstall the ink back try printing.
Let me know what happen..
Kevin
Posted on Apr 16, 2009
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Near empty black is displayed even with new black cartridge
If you replaced an ink cartridge while Near Empty was displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes 2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand new one, please be sure to select 2.
WARNING
If ink gets in your eyes, irrigate them with water immediately and call a doctor if you are concerned.
If you wait until Ink Empty message is displayed on the LCD, the machine will automatically reset the ink dot counter.
If the Install message is on the display after you have installed ink cartridges, check that the ink cartridges are
installed properly.
Jan 01, 2011 | Brother IntelliFAX-2440c Plain Paper...
My Brother Dcp-150c's cartridge sensor seems to be malfunctioning, it says black cartridge empty and color cartridges almost empty, even when replaced with new cartridges. Ist there a way to fix this error...
My Brother Dcp-150c's cartridge sensor seems to be malfunctioning, it says install black and ink empty and offline even when replaced with new cartridges. Ist there a way to fix this error or do I have to replace the cartridge sensor inside? Thanks.
Oct 23, 2010 | Office Equipment & Supplies
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Ink level status on black ink is not accurate
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother printer MFC 420 CN
I wouldn't be surprised. Since you're going to need black ink eventually anyway, put in a new black cartridge and find out.
Sep 16, 2008 | Brother MFC 420CN All-In-One InkJet...
k24674
