Question about Uniden 5.8GHz Dual Cordless Phone
No dial tone on one of my dual set phones model #dx18560-2
  • 89 Answers
You have to register the phone to the base. Read the instructions for adding additional handsets. Regardless if it came with two handsets, one of them may not have been registerd. Sometimes it's as easy as setting the handset in the base, not the extra charge cup, for about 10 seconds. Other times you may need to use the menu on the phone and hold down a button on the base. Good luck
Posted on Apr 16, 2009
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
Is it possible to call out with this phone,it has an old fashion dial
I assumed your old-fashioned phone works in Pulse (Rotary) mode only. Maybe the Tel Company or the Private Tel Exchange in your house supports only DTMF (Dual-tone Multi frequency) or MF (Multi Freq.) tone.
Sep 05, 2015 | Lands Phones
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
How do I get a dial tone.can answer the phone.just cannot dial out
I am NOT familiar with YOUR make and model of phone, BUT.... I've had several cordless phone systems over many years, and have had the same problem that you describe. First, here is some background info for you:
The telephone company systems USUALLY have two different dialing systems:
  1. The "old" ROTARY DIALS worked by MECHANICALLY sending out different numbers of electrical pulses which the MECHANICAL "receivers" at the phone company "Central Office" buildings would read and thus connect you to the dialed number.
  2. Some years ago, a "new" dialing system was initiated. That system was called Dual-Tone-Multi-Frequency [or for short, DTMF].
DTMF uses BUTTON KEYS which put out a different electronically generated TONE [related to] for each different NUMBER key pushed, and THAT series of tones told/tells the phone company Central Office receiver computer the number to which you wanted to be connected.
Around the world over the years, most phone companies have, and still use one of these two dialing systems, AND...
Most cordless phone manufacturers designed their phones to work WITH EITHER system, BUT....
The customer IS REQUIRED to "SELECT" which system his phone company uses, while the customer is "SETTING UP" his/her new cordless phone.
THAT process IS INCLUDED in ALL cordless phone set-up instruction packages I've ever seen!!!!!!
Either you need to carefully read and study YOUR installation-set-up instructions and then PROPERLY set your phone's dialing system [to PULSE or DTMF], OR GET SOMEONE who KNOWS WHAT he, or she is doing to do it for you.
I, and I think no one else is able to guide you via back and forth messaging on this site. At least I know I can't because I'm not acquainted with your cordless phone, AND I don't have an instruction/set-up manual to consult!!!!!
Track down your manual, OR search for a replacement manual; the dialer system selection process is NOT DIFFICULT IF you have the manual!!!!!!!
Nov 25, 2014 | Vtech CS6649 - Multi Handset Phone System
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
How can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Jun 01, 2008 | Uniden 5.8GHz Dual Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Uniden 5.8GHz Dual Cordless Phone Logo
175 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
