Question about Panasonic NV-GS15 Mini DV Digital Camcorder
Black Bars I have the NV-GS15 also, Whenever I play back a tape (either on the camera or TV) the picture is obscured by horizontal black bars Its not the tape thats at fault so it must be the camera?
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    please clean the head using head cleaning cassette , it is dirty
  • 24 Answers
Try re-setting the camera by pushing the reset-switch with a small object (like a pen).
Posted on May 09, 2009
Horizontal equally spaced black bars accross the screen when in playback mode similar to looking through partially opened venetian blinds.
You may need to clean the head on the device. You can purchase head cleaning tapes from most stores that sell the tapes, or goto a specialist camera shop.
Failing that, open the tape slot, tape the tape out, and with a soft cloth see if you can clean the small silver heads very gently.
Oct 20, 2010 | Panasonic NV-GS15 Mini DV Digital...
Black bars on zr300
Cleaning Tape did the trick. Thanks!
Andy
Mar 30, 2009 | Canon ZR300 Mini DV Digital Camcorder
My panasonic nv-gs15
The symptom appears to be video head clogging. I would first try to use head cleaning tape. (use new one). Run the cleaning tape for about 10 seconds but not more and see if it resolve the problem. If not, camcorder need a tracking adjustment by a technician. Good Luck. James. For further assistance, go to www.camerarepairjapan.com
Mar 26, 2009 | Panasonic NV-GS15 Mini DV Digital...
Image Sensor Problem
Does the black line record on the tape? When you play back on a TV/Computer can you still see the black line. If you do that would be the image sensor.
Good luck!!
Feb 13, 2009 | JVC GR-D850 Mini DV Camcorder
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Panansonic NV GS15
same thing happened for me. Helped resetting the cam.
Apr 06, 2008 | Panasonic AG-DVC30 Mini DV Digital...
Black stripes with Panasonic NV GS320
"a little tap on the bottom of the camera solve the problem of the black strips..."
I know for sure a little **** in *** solves definitly black strips trouble, please give a try.
Feb 03, 2008 | Panasonic NV-GS15 Mini DV Digital...
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Playback problem on Panasonic NV-GS15
It is probably a dirty head. One camera i had i had to clean it much more often that i wanted to and certainly before any important shoot.
Here is a tip though. Always use the same make of tape (and code). If you do change your tape (or code) then clean the heads before you put in the different tape. this is all to do with "dry or wet" lubrication used on different tapes. i do not know enough about that to comment, but the tip comes form a very good source.
Some people run the whole tape through on record (with the lens hood on) before they use it. I do not think it will help for this problem, but you can try.
Nov 12, 2007 | Panasonic NV-GS15 Mini DV Digital...
BLACK Lines and having to reset.
i assume that the 'black lines' are 5 bars of dark video spaced equally across the screen. this is a symptom of dirty heads. use a mini DV cleaning tape, and the problem should go away.
Jun 09, 2007 | Panasonic NV-GS15 Mini DV Digital...
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
212 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
