Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower shuts off when clutch is disengaged.
My Craftsman mower shut off when I disengaged the clutch. Can anyone help me?
  • Anonymous Apr 29, 2009
    when i let the clutch out the riding mower it stalls jumper wire under the seat.
  • John C Bridgers Sr May 11, 2010
    Hello m_holmes_76:
    >>Are you Saying the Engine Quits when you Push the Clutch in?
    >>Thanks.
    Respectfully
    John
    Problem Solver:
  • 6 Answers
Check your seat adjustment to make sure you're applying constant pressure to the safety switch under the seat.
Posted on Apr 22, 2009
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
Bracket clutch anti-rotation
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Feb 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower Model 917.270824
I do not believe there is a manual available to the public for troubleshooting, however, you have at least 3 switches to tell the mower to stop when blades are engaged or clutch pedal released.
Seat switch
pedal switch
mower engage switch
The pedal and mower lever switches are identical, and have two sides, one for starting, one for blades turning. One side can fail. The pedal switch is on the frame very close to the pivot point of the pedal/shaft. The mower switch will be under the dash close to the bottom of the lever.
1) Locate and inspect the switches for broken or pinch wires, switch housing, or loose mounting, and how each lever or pedal engages the swtich.
2) This is a picture of the wiring so that you can get a better idea of location.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00011&componentDescription=SCHEMATIC%20DIAGRAM-TRACTOR&documentId=P0811014&blt=06
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00001&componentDescription=ELECTRICAL&documentId=P0811014&blt=06
Nov 11, 2009 | Craftsman Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
509 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
