Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
Whirlpool dishwasher Model GU1200XTL 80, Serial #FM4515914. The two fans are not turning though the machine seems to be running but nothing happens besides the water will fill up then drain out. Nothing gets clean. There is nothing blocking the fans and it was working fine. Please advise - thanks.
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Gold Dishwasher Model GU2400XTP
There should be a thermal fuse located inside the console on the control board. Most dishwashers have them mounted this way. It's a white square plastic piece, or silver component with two wires connected to it. If the thermal fuse is bad it will give the same symptoms you are describing. To check, you need to turn off the circuit breaker to the dishwasher and remove the screws holding the console in place. This should be the four or five screws at the top of the door (with the door open). Carefully lift the console off the door (support the wires) and flip it over so you can see the control board. The thermal fuse should be mounted somewhere on the control board. The fuse will read a SHORT if good, an OPEN if bad. The fuse is not resettable (meaning you can't reuse it) and must be replaced. If you need further assistance let me know. I hope this helps you. PS There should be a tech sheet located inside the lower kick panel under the door. This includes all the schematics and troubleshooting tips. You may use this as a reference too.
Posted on Jul 18, 2007
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
  • 25 Answers
SOURCE: Dishwasher will not fill with water
Bosch D/w Have a float switchin the base pan of the unit you can access by removing the toe kick, if there is water in this base pan it turns the drain pump on and will not do anything else. So until the water is removed either vacume it out , or let it evaporate or however the unit will only drain
Posted on Jan 25, 2008
  • 351 Answers
SOURCE: Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Posted on Mar 20, 2008
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
Why won't my whirlpool 10kg sports washing machine model number wfe1210cs turn on?
Check this attached link, it may give you incite on your washer problem
May 27, 2014 | Whirlpool Washing Machines
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
Whirlpool dryer will not turn on
Hello Wpdodd, we're sorry to hear about your Dryer. Unfortunately we are not able to provide technical assistance. If you would like for us to schedule service for you then please email us your name, phone number, address, the model and serial number and the website you were contacted on (Fixya.com) to Whirlpool_Digital@Whirlpool.com.
May 09, 2017 | Whirlpool 3.2 cu. ft. Washer
Detergent sticks in main wash compartment. We use cascade complete with bleach (hydroclean action). When this problem started, I switched to cascade complete (liquid) and still same thing happens. The...
Jsmarquez, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Jsmarquez), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 25, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Hobart glasswasher: it fills but then nothing
Did you solve your problem?It takes 8 minutes to fill.I'm a hobart tech,let me know.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Cycle seems never-ending
on the ECO 50 cycle dish washer will not stop. have had to switch it off, when try to restart it automatically goes back to the ECO 50 programme. Can you please help. The Serial No. is ADP 2440 WH.
Nov 24, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
79 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
