Question about Mag Innovision LT765b 17" Flat Panel LCD Monitor
Wont power on
Was using the monitor, suddenly the colors got brilliant (esp. the reds) and it died. a few days later it worked again, only for the same thing happening again. this time it didnt fix itself. nothing happens, not even the orange/green indicator comes on. i tested it with another power supply and it still wont power .up i have two of these and both power supplies work fine with the other LT765B
  • dan spengler Sep 17, 2007
    first let me thank chansn for responding to my question. i have written in questions to many different forums in the past but no one ever responded! second, let me thank chansn for the correct solution! IT WORKED! I don't know why it worked, but it did! The reason I didn't try this earlier is because the connector on the monitor end was very tight and crammed into too small of a space for my chubby fingers. THIRD, the response was very timely and saved me from going out to buy a replacement. Three cheers for chansn !!!
  • lswinford Nov 01, 2007
    I have disconnected my MAG Innovision LCD monitor from the PC and power, and even left it disconnected from power for over a day, but when I connect the monitor back to the power supply it still will not power on.
    The little green light on the power button just blinks green.
    The monitor is less than 2 years old, Is it fried?
    Problem Solver:
  • 18 Answers
Hi , please change the signal cable which is connected from CPU to monitor. please rate this comment.
Posted on Sep 17, 2007
SOURCE:
My samsung phone wont turn on it just blinks red when on charger or power button pressed
Remove the battery for a day, so it will forget its current state. Then put it back in and try again.
Dec 20, 2013 | Televison & Video
2006 Jeep Liberty Diesel, Cruise doesn't work. Cruise, ESP and ABS dash lights on
You must have the systems scanned for fault codes before any reason can for the problem can be given.
Jul 16, 2012 | Cars & Trucks
I have a lcd monitor citizen tv set LT2010 , suddenly it doesnt work anymore and there is a blinking red light, i unplugged and nothing work.. please help me
Monitor power supply board have dead components parts call capactiors most likely.The power supply board that the board where the power a/c cord plug into it.U have all the tools and know basic electronic also can do basic soldering works?Yes,take it aparts and check the power supply board carefully and replaced all the dying or dead capacitors components capacitors parts,these dying capacitors parts dying are alway bulges and puffing up onto it tops.Replacing all the dying and dead capacitors that are having bulges or puffing up onto it tops,monitor will have red power light indicator LED light stable again and will stop blinking.The monitor will work again.
May 11, 2011 | Televison & Video
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Moniter is not powering up.
unfortunately. This is a classic symptom of a faulty inverter board. I would suggest looking on ebay to see is there is a cheap replacement. Purchasing a new one is usually not economical these days.
Jul 11, 2009 | Sceptre x22wg Gamer Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Red tinting with the Acer LCD monitor AL1916
Amazingly enough my monitor did the same thing and while looking for the serial number the problem got resolved. Since I don't know exactly how it got fixed I will tell you what I did. I turned the monitor off, removed the power cord from the unit, turned the surge protector off and back on, placed the monitor face down on my chair to read the serial number, reconnected the power cord and turned the unit back on. The problem was fixed. Go figure.
Nov 16, 2008 | Acer AL1916W 19" LCD Monitor
IBM CRT Monitor - monitor off, red LED flashing
This monitor is worth $30.00. Trash it. http://www.etech4sale.com/IBM_6549_4AN_G96_19-Inch_White/G96/partinfo-id-119721.html
Jun 25, 2007 | IBM G 96 (White) 19 in.CRT Conventional...
Mag Innovision LT765b 17" Flat Panel LCD Monitor Logo
147 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
