Question about Mitsubishi Diamond Plus 73 17" CRT Monitor
Mitsubishi monitor is distorting the picture
I have a mitsubishi Diamon plus 73. About 5-6 years old Last night when i turned it on the image on the screen was shrunk. Although the width was approximately the same ( albeit bulging down the sides) its height had shrunk from both the upper and lower edges. another way to describe this is that it almost appeared wide screen with large black bars at the top and the bottom. None of the image was lost it was just squashed into this space i was considering opening up the case myself to have a look for a loose wire or something. I hav efound that if i place my hand on top of the monitor and wiggle the screen returns to normal. I have tried wiggle the 2 cables at the back of the monitor but they dont really seem to be the cause. So perhaps there is a component situated above the tube and between the case? Any tips on what to look for? PLus any tips on how to open the case as there dont appear to be any screws? amd i dont want to damage it. Thanks
  • 3 more comments
  • KINGSWORTH75 Sep 15, 2007
    Hi thanks a lot for the help.
    i have removed the cover from the monitor. how do i go about identifying the parts you talked about?
    perhaps you know of an image which would explain which part was which?
    I found a manual for another Mitsubishi monitor over athttp://fileshare.eshop.bg/downloadsm/273...
    I have attached some images that i have cropped from that. although it is not the same monitor, is the part your on about inside the thing i have ringed in red?
    Also what does IC stand for in vertical IC?
    What are the shields?
    Im sure i can do this i just need some guidance.
  • KINGSWORTH75 Sep 18, 2007
    Hello there and thank you for your help.
    I have a concern about stored electricity in the monitor.
    I you watch this videohttp://www.youtube.com/watch?v=C8zYeFnkt...
    it shows you how to discharge the electricty. However, if you watch you will see he connects one end of the wire to screw driver and the other end to another part of the monitor. Will this work? i am not good at electronics but wouldnt this just leave all the electricity in the monitor. The monitor is not plugged in so where does the discharge go? if this is reasonably safe please let me know.
    also having trouble finding the tsib.... im sure it should be on the larger mainboard, but cant see it at the mo and dont want to fiddle too much until the monitor is discharged. Is this where i should find it?
  • 65 Answers
Well first af all ,you never find this "loose wire" because it is a mith. what you have is a "cold solder" in the vertical IC, if you have a solder iron , and the ability to open it (without scratching), and then take off all the shields (without cutting your fingers), and get the solder area (without breaking the Tube). at this time ,it take you 1 minute to solve...!!! iF not... leave it to the repairman!!!.
Posted on Sep 15, 2007
  • kbza loka Sep 15, 2007
    i correct myself, loose wire = myth
  • kbza loka Sep 16, 2007
    ok, you are on the way, the part you marked is CRTBoard, there you must go if you have problems with red,green,blue or bright problem !!! not your case.
    the "shields" are all the metal parts that are around the tube, mainboard,CRTBoard,etc.
    ok, the ic you are looking for is the one that
    in schema you refer is TDA4867 ,a 9 pin (not 32 as you read in this manual).
    in your monitor, maybe, TDA4860 to 67, or tda9302 or tda8172, find it and resolder.
    Remember unplug it and wait a few seconds to discharge caps.
    As you told "i place my hand on top of the monitor and wiggle the screen returns to normal"
    you have fix it.!!
    Felicitaciones!!!.
SOURCE:
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Have a 73" mitsubishi model No.WD 73734 and I have
On the TV not the remote, simultaniously press the menu and input button for at least 5 seconds. This should give an error code. If it blinks 3 times then a pause then blinks 2 times, the code would be 32. Get your error code and look in the service book at: http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf -
Sep 22, 2011 | Mitsubishi WD-73734 73" Television
65" Mitsubishi TV
cannot get any sound at all from tv
Jan 28, 2010 | Mitsubishi WT-46805 46" Rear Projection...
73" REAR PROJECTION MITSUBISHI STARTED DOING 3D
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 21, 2010 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi WS-55809
can you post a picture of what the picture looks like? If so I should be able to diagnose the problem
Apr 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi Diamond Plus 73 17" CRT Monitor Logo
90 people viewed this question
Top Mitsubishi Computers & Internet Experts
Alun Cox
John Waters
John Waters
Tom Chichester
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
