Question about Mitsubishi VS-60603 60" Rear Projection Television
Autoprograming My TV has gone into a "Installing Guide Plus data now turn tv off during installation home to delay and cancel to abort mode". Problem 2. I lost the original remote years ago. Its been on this mode 4 three days. Thanks for reading this.
Get the original remote.....i had to. it costs $95 thru best buy(special order it takes 5 days)
Posted on Oct 15, 2007
SOURCE:
MITSUBISHI VS-60705 Comcast related. Power went off, TV was not showing comcast anymore, I tried installing Channel Plus + and now cannot abort the message. The message has been on TV for 3 days already....
Check with comcast but have you tried to remove power from all units involved here for a while, then power back to see if the reboot will help or not.
Oct 30, 2012 | Mitsubishi Televison & Video
RCA F13137--Have direct connection from cable (basic only) to TV. Autoprogram only finds 16 channels. Same set up with another TV in same jack finds 75 channels.
Make sure to check in the guide plus setup for the question "Do you have cable?" and answer it yes. Be sure that you answer the question "Do you have a cable box?" NO. It sounds like it is in antenna mode. Thanks
Oct 17, 2009 | RCA P61939 61" Rear Projection Television
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
How do i stop the tv guide plus from loading?
when this has happened to me in the past; if I remember correctly I hit home, stop, cancel, etc any of those gets it to send me the banner that if I stop now......it is not going to CANCEL loading!!! I'm thinking YEAH!!! and then I select the prompt to cancel. I then hit menu again, to cancel and I believe I select home...Now perhaps you think I SOUND a bit "iffy" it would be true; seeing how it has been at least 3 months since it has happened and I sure not going to go and hit that ****** to walk you thru it(he he) sorry but I know you know how it is!!! GOOD LUCK DON'T GIVE UP AND DO YOUR BEST TO NEVER HIT THAT TVGUIDE+ AGAIN (i have many times and its always a pain in my brain)
now get her done!
Mar 02, 2009 | Mitsubishi VS-50603 50" Rear Projection...
TV Stuck in TV Guide Plus+ Installation Mode
buy a good universal remote and it will have the correct button, that's what I did, I got the Radio Shack 8-in-1 remote and programmed it and it got rid of it.
Dec 03, 2007 | Mitsubishi CS-36609 36" TV
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Have a problem with mits. vs-55601
The cancel button on the Base unit doesn't seem to work for this, you have to use the "Cancel" Button on the remote. Once you hit "Cancel" on the remote, the scan should exit, and then the buttons on the base unit should work again (barring any other issues). You should also be able to allow the scan to finish (takes a while especially if no signal on the channels), and when it's done it will exit. Hope that helps. Buzz
Aug 20, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
