Question about Garden
Willnotrecoil starter rope will not recoil on my leaf blower. weedeater featherlite mod.# fl1500le...
  • larry prince Apr 21, 2009
    I have weedeater featherlite gas blower that did the same thing so I order new parts - spring coil & pulley - I can't figure out how to put it all back together
    I have a weedeater featherlite gas blower would not recoil so I order new parts - pulley & starter spring but can't figure out how it all goes back together
    Sniper:
  • 60 Answers
Hello . First thing is remove the starter rope and check to see if the flywheel turn by hand . If turn by hand you have a bad recoil starter , if does not turn by hand the piston is seized . Remove the spark plug and put 2 or 3 drops of oil (2stroke mixing oil) on the spark plug hole and try to turn it again by hand . If still does not turn you have to replace the piston and maybe the cylinder .
Hope this help
Posted on Aug 29, 2009
My fb25 starter rope won't recoil. how do I fix this please?
has to be taken apart for that, spring probably popped out of its groove
May 30, 2014 | Weedeater 25cc 2-Cycle Gas Blower - FB25
Pull cord is hanging out and will not restring
the recoil system is worn out (have to buy and replace it).
May 15, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Need to know how to replace string on weedeater gas blower FL1500LE
The Weedeater FL1500LE is a 23cc 2-Stroke Gas Blower and does not use string. It only uses air.
Mar 31, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
How to repair spring starter on FL1500LE
The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
Nov 24, 2009 | Poulan Featherlite Gas Blower, with Low...
Weedeater pull cord won't pull out on a leaf blower
Suggest to remove recoil housing/assembly and try to rotate the flywheel. Remove the spark plug & check for a silver or aluminum color or coating.
If the flywheel will not turn by hand, the piston/cylinder is seezed. No further repair is affordable.
If the flywheel turns by hand and the spark plug is a dark brown color, then focus your attention to the recoil assembly to see if rope is bound or wound around the rope rotor.
Nov 10, 2009 | Poulan Garden
How to get the spring & starter rope back together on a weedeater featherlight leaf blower. model #FL1500LE
easiest is to take a slotted screwdriver, poke into the underside air intake and rotate the wheel a bit...usually the rope goes right back in...if not take the three screws out and release the rope.....while your there give it a few twists to loosen it up....you will do this soon enough when the rope breaks :)
GG
Nov 05, 2009 | Poulan Featherlite Gas Blower, with Low...
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
MY ROPE WONT GO BACK IN?? HOW DO I SOLVE THIS PROBLEM..THANK YOU IN ADVANCEITS ON A WEEDEATER FL1500LE
well, either the screws that hold the plastic on (thats hooked up to the rope) are loose, or the spring in the recoil is wedged, missing, or dislodged. Might want to take off the recoil and check for any missing parts, wedged in or dislodged. if none of these is the case, try asking a person at your local hardware store, (home depot, westlake, strausser, harbor-freight, Lowe's)
Jul 10, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
651 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
