Question about HP iPAQ hw6515 Pocket PC
Keypad lock code
I cannot remember the keypad lock code of my iPAQ.ill tried many times to intered number but unsuccessful
  • Anonymous Jan 08, 2009
    nokia
  • 490 Answers
Save ur data on to mem card and remove ur battery,,put it back. switch on the phone again.
Posted on Oct 19, 2007
  • J Jain Oct 20, 2007
    try with normal reset path put ur stylus on the hole which is loctaed on the left hand side of ur phone but before doing it take ur memo. card out of it or try with hardreset but before doing it plz take back up up coz it may lose ur data . path click on n/w bars u wil get format options good luck
Nokia 6280 needs restriction code
Try the soft reset and see if that solves whatever issues it is you have. Using the dialing keypad type in *#7370# and then inter your lock code (default is 12345).
May 05, 2014 | Nokia (BP6M) 3250 6280 6282 6288 6233 6151...
I have an HP iPAQ 6920 with a Keypad Security Lock Code. My son while playing with the phone repeatedly entered the wrong code and now it's not accepting my original code. Also there's now a 2m 08s...
Welcome to Fixya
Passwords are encrypted type. There is no special code that you need to enter to bypass the password for this unit. The only way for you to use this unit again is to do a Hard Reset. Meaning everything will be back to original factory state. If you decide to do that, then please follow the procedure below:
A clean reset clears all user-installed settings, programs, and data, and restores
your HP iPAQ to factory settings.
To perform a clean reset and return your HP iPAQ to factory settings:
1.Press and hold the Answer/Send, Power, and End Call buttons.
2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Thank you for using Fixya!
Dec 24, 2010 | HP iPAQ hw6920
My Nokia 3110 has got security code to unlock the keypad. I forgot it and typed wrong codes more than 10 times. I think it has got locked. Plese help me.
after you insert 3 times the wrong code, the keypad is blocked for a certain amount of time. Try to remember that code. I personaly don't know any other unlocking method
Nov 03, 2010 | Nokia 3110 Cellular Phone
Cannt inter bios becuse close by password acer 5720
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Aug 04, 2010 | Acer Aspire 5720-4230 Notebook
Subsidy Unlock code for att lg gr500
Make sure the phone is on so that you can enter the appropriate code. The unlock code is *#865625#.
  • Entering the code
The phone needs to be on for you to enter the appropriate code. You will need to keep the SIM card in the phone so that it recognizes the phone's unlock code. Enter *#865625#. The screen will then ask you if you want to continue. Select yes.
  • Second code
You need to enter the code a second time. So basically, just repeat the first steps mentioned to enter the unlock code given above. Once the code has been entered a second time the screen should read that the 'Network Unlock is Deactivated'. The code and the unlock work for the GSM network, meaning that if you want to use the phone with a different service provider you are now able to.
  • Other unlock
Sometimes one does not want to unlock the phone for GSM network use, but because the keypad is locked. If you have locked the keypad and this is what you want to unlock try the last four digits of the phone number. This is often the default code for the number pad. If that number is unsuccessful consider what you might have personally used as a four digit pin. Most of us use the same number that belongs to our ATM or other device that requires a four digit pin.
If the code provided in the first steps is not the correct one, you may want to look for a sixteen digit code on the back of your phone. It may be on the battery or just behind the battery. It tends to look like a barcode. Sometimes companies use this code as the locking mechanism for the GSM network. Tolearn more you can see our unlock-any-lg
Dec 23, 2009 | LG Xenon GR500 Cell Phone
My phone is locked and i don't know what the lock code is
try the last 4 digits of your phone number. If that doesn't work dial *228 option 1 then try the last 4 digits of your phone number.
Dec 22, 2009 | LG enV VX9900 Cellular Phone
Keypad is locked
Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that.
Aug 01, 2009 | RIM BlackBerry 8700c Cellular Phone
Need the factory keyless entry code to reprogram drivers door keypad. Owners manual insert is no longer available.
Check inside the trunk lid for a label with a 5 digit code. If unsuccessful, then any dealer would be able to help you by checking the VIN number.
May 11, 2009 | 1998 Lincoln Continental
Lock
the default code is 12345 if u changed it and dont remember try not to lock the keypad or else ur gonna av to re power ech time
Jan 26, 2007 | Nokia 1100
HP iPAQ hw6515 Pocket PC Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
