Question about Samsung SPH-M500 Cellular Phone
Camera wil not work
When trying to activate camera "preview error" message appears and camera will not turn on.
  • Anonymous Mar 20, 2014
    when i open camera the message was written preview error
  • 89 Answers
There is a virus in your phone claim the warrenty or get your mobile format
Posted on Sep 17, 2007
SOURCE:
Camera of genoa is preview error
try, basic trouble shooting steps on the phone.
-turn it off and then on
if it won't work,restoring the factory settings of the phone. :D
May 02, 2012 | Samsung C3510 GENOA QUAD BAND TOUCH SCREEN...
Lens error
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
May 28, 2008 | Nikon COOLPIX S10 Digital Camera
Lens error
Hey Wiggs12485,
This error message appears when the camera detects a problem with the lens when it's turned on. This is often caused by the user pressing on the lens when it is trying to extend, or the camera is being used in a dusty or sandy environment. When this message appears turn the camera off and back on, and this should resolve your issue. If this message continues to appear you should have the camera looked at by an authorized service technician because there is probably a problem with the lens.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Sleepy Scanner?
try using windows driver first, so that we will knowif there is a problem with your scanners driver.
Open paint and click on file and click on from scanners and camera and let me know if it will give you an option to scan from that app or if you will get an error message.
Apr 02, 2008 | Epson STYLUS CX5900 Printer
"preview error" message for camera
inside your phone there is a yellow wire that conects 2 ure camra if ur fone is doing what u sead that means that is the yellow wire is loose or snaped and have to go to your company to get it fixed
Jan 30, 2008 | LG VX5300 Cellular Phone
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Can't see the image in PC
It sounds like the images are corrupted. On many cameras, a camera-only preview is also stored alongside the image file, so the camera can quickly display the preview without having to spend time decoding the image file. When you try to apply the zoom, the camera is actually trying to decode the image, which fails because it is corrupted. This might be due to low battery (unlikely), or bad memory. You might try replacing your memory card.
Feb 15, 2007 | Samsung Digimax S500 Digital Camera
When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the LCD monitor.
Please follow the procedure below: 1. While the message is displayed, press the center of the controller. 2. The LCD monitor and data panel will turn off . 3. Turn the Main Switch to OFF and remove the CompactFlash card from the camera. 4. If "No Card " message appears at next time the camera is activated in the recording mode, the camera and CompactFlash card are OK. 5. In case that "Card Error. OK" appears again, the CompactFlash card may be faulty. Use other card.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Samsung SPH-M500 Cellular Phone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
