Question about Acer 22" X223w LCD Monitor
How to angle the monitor
How do I angle the monitor, is ther a button somewhere to make it move?
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Posted on Jun 22, 2009
My Acer monitor has 3 inches missing on the left side and 3 inches black on the right
There should be buttons somewhere on your monitor...one named 'Menu' there you should click on an option to change the positioning or horizontal/vertical then follow the instructions...usually the arrow keys...to move the frame to where you need it...hope I helped!
Jan 13, 2015 | Acer 22" X223w LCD Monitor
MY SCREEN IS TO FAR TO THE RIGHT I CAN'T MOVE IT TO THE LEFT
To move your screen from right to left or up or down, you want to use the buttons that are on your monitor. Look on the front of your monitor, or on the side or bottom. Somewhere on your monitor are controls to change that
Feb 20, 2013 | Office Equipment & Supplies
My Power Acoustik PTID-7350NRBT angle feature isn't working
If you're still looking for help I have the same one and had the same issue. You have to push the eject button once and right after push and hold it and it will let you change the angle. You have to be really quick between the push and push and hold. If it opens, just close and try again.
Jun 29, 2012 | Power Acoustik PTID-7350NRBT 7 in. Car DVD...
Installed AOC 2436vh, top of screen off of physical structure of screen, tried power down, physical reinstall, roll back of driver and reload of cd, how do I uninstall monitor to try again? Or adjust it...
I have the 2436V (no speakers), but I suspect the solution will be similar. My screen was a bit to the left of the monitor's physical display area, and I was able to solve it using the built in menu (If you take too long deciding what menu button to press next, the menu will time out. Just start over if that happens. You will get faster with practice).
1) Press the menu button on the monitor (the menu appears).
2) Press the up button on the monitor 4 times to highlight the icon that looks like a slightly angled screen with yellow cross-hairs in one corner (the toolbar for positioning the screen appears - all 5 icons on the positioning toolbar are blue).
3) Press the menu button on the monitor to "enter" the selected toolbar (one of the toolbar icons turns green to indicate the selected tool on the toolbar).
4) Select the tool you need using the up/down arrow buttons on the monitor (I needed the one that moves the screen horizontally, you need the one that moves the screen vertically).
5) Press the menu button on the monitor to activate the selected tool (the meter above the toolbar icon turns green to indicate the tool is active).
6) Use the up/down buttons on the monitor to position the screen.
7) Press the menu button to exit back out (or, just let the menu time out).
Note: the disk that came with the monitor doesn't seem to have drivers for Windows 7, but allowing Windows to search online while updating the driver found a compatible driver online.
Dec 22, 2010 | AOC Monitor
Screen cuts off image
To see the button on the right hand side of this monitor you will need to shine a really bright light on it, but the buttons from top to bottom are: 1, up-arrrow, down-arrow, and 2.
  1. On the side of the monitor press the 1 button to activate the menu.
  2. A configuration menu for the monitor will appear; from that menu highlight the "Input Select" menu item using the up and down buttons on the monitor; when you have the item high-lighted, press the 2 key.
  3. A new menu will appear, and then you can select the menu item called HDMI on the left and PC waaay over on the right. Select this menu item with the up and down arrows and when it is selected,
  4. And press 2 like you did in the previous step.
Apparently there's some sort of a strange difference between using this monitor as a "video monitor" and using it with a computer.
Nov 02, 2009 | ViewSonic VX2433WM 23.6" Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
I have a syncMaster 997 DF it is acting like it has no powere and will not come on - it has done this before when i moved it to change locations to a different desk - then the next morning i plugged it in...
probly you have loose conection...the wires that connects the monitor might be broken...try moving(shaking) the wires will it is power (AC current is given to it)...press the power jack harder into the monitor....or else it can be some internal faliure
May 10, 2008 | Computers & Internet
Acer 22" X223w LCD Monitor Logo
401 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
