'.iso' is an image format. To open an iso file you need to install any one of the softwares called 'magic iso, ultra iso, power iso etc. After insatlling any one of these software the .iso files icon changes into a recognized iso file format. You can now double click to open to and view whats its contents are, if its a software iso file you have to extract it first to a folder. Good luck
To change the ISO on your Polaroid t1031, please do the following:
Turn your camera on
Press the FUNC (Function) button (right button on bottom right of device next to the LCD)
Use the Up/Down, Left/Right buttons to move through the menu.
Scroll down to the option that reads ISO AUTO and press the SET button (located in the middle of the arrow buttons) to bring up the different ISO options available to you (see Fig 1 below)
Use the arrow keys to navigate the different ISO options and press the SET button to confirm your selection.
If the menu does not close on its own after making your selection, press the FUNC button to close.
To change the ISO setting: press the F button to display the F-menu. Use cursor-up/down to select "ISO" and press cursor-right.
In general you want the ISO as low as possible in order to keep the noise down as much as possible. However, in low-light situations or photographing fast-moving subjects, low ISO values may lead to excessive blurring. In such situations you may want to use higher values since a noisy picture is better than no picture.
The ISO is set to Auto and can't be changed when shooting in Basic Modes (all of the icons and the green circle). ISO can only be adjusted in Creative Modes (P, Av, Tv, A-DEP, M). If you want to adjust the ISO in Creative Mode, press the ISO button and then turn the dial next to the shutter trigger.
ISO can be changed in P, S. A and M mode only.
You cannot change the ISO in AUTO or SP mode.
Press Menu/OK and use < and > to select ISO. Use
up and down arrow to change the ISO. Press OK
You can only cahnge ISO levels in MANUAL mode, I assume you are trying to change in AUTOMATIC mode, which you canoot do as settings are automatically adjusted for lighting conditions. Hope this helps you.
If your error is about your images being brighter/darker whenever you shoot at different locations, then this is a normal feature when using Auto setting for your ISO. The exposure will always slightly change whenever the ISO changes.
If your problem is about too much noise, then this is a normal problem when you use very high ISO on the D80. You can remedy this by setting the max ISO to 400 but you will not be able to take non-flash pics in darker environments.
If your problem is the ISO levels do not go up a certain setting, change your MAX ISO setting to a higher number like 1600. At this setting, the pictures will be grainy and have a lot of noise so I recommend you convert the output to black and white.
NOTE: Please rate our help to keep this free service online
You can change the ISO setting also to Auto. If you have the advanced guide (see pp 80, 107).
Press the ISO button it will switch from various ISO setting to AUTO.
Do remember in Bright light , a lower ISO number like 80 will give you very fine images, while as the light level goes down, the ISO number will change to a higher number and the image will become more grainer.
I hope I could answer to your query.
Please do rate. Thanks
