Home | Dishwashers | Homark semi int...
Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Homark semi integrated dishwasher 01/...
By dadyo on Sep 15, 2007
My dishwasher will not fill properly. It does get a little water but not enough to cover the electric heating element inside. I can empty it. Is it a water level switch problem.
Any help would be gratefully recived.
Comments:
Jan 27, 2008
- It turns out that old dishwashers do not have a water sensor switch underneath to know when seals have failed and water is leaking slightly. The whole underneath was really rusty and the dishwasher had to be scrapped as it was uneconomic to repair. New dishwashers should have this water sensor switch so make sure that it does when purchasing.
Same Problem
Dec 27, 2007
-   fills with water but does not cover the heating element. Heating element gets warm MACHINE DOES NOT GO THROUGH ITS CYCLE BUT DOES EMPTY WATER OUT-   RUDDBOY
Best Solution
posted on Oct 17, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
seal gone on bottom of the door
Solution #2
posted on Nov 24, 2008
Not Rated)
chunky ian
Rank: Apprentice
Rating: 0%, 0 votes
i think i may have the same problem, the timer on my mchine may have broke, first the detrgent door would not open, then the heater element would heat intermitantly. problem i have is the timer is obsolete, machine is 14 years old the inside looks new this is the firsty and possibly last time it let me down to check opperation hold the timer knob firmly push in simultaniously turn sloowly through the stages the timer may opperate as the contacts would not have worn. my theory!!
Chunkster
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
what brand dishwasher should i buy?
Answer
What new dishwasher do you recommend. I have a family of 7 and the dishwasher is constantly in use.
Answer
stuck on clean cycle
Answer
The door switch on my belling idw603 dishwasher is broken is it difficult to change?
Answer
The nylon cable on my KitchenAid Dishwasher KUDPO1FL has broken where it attaches to the door. Left... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
