Question about Alpine Car Audio & Video
Hi there I have lost my housing for the 7179es the part that stays with the car. As this is a removable device. I wish to make it permanent. Can I have the wiring color codes for this unit. Regards Gary. I have had the unit apart and think that the main power is red, but I do not know weather this unit uses the orange for the acc connect as well. In witch case I will join these to wires together.
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
  • 35 Answers
SOURCE: How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
Posted on Jul 06, 2009
etirbynnor
  • 655 Answers
SOURCE: ok, here is a list of the factory wires coming
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Posted on Aug 12, 2009
Testimonial: "thank you greatly. that does help alot."
How do I delete books on my kindle paper White
To delete books tap and hold the title of the book you wish to delete then select "remove from device."
Alternately you can delete them from your Kindle account in your online settings and then they will be removed from the device the next time you sync but that may permanently delete the item from your collection.
Feb 28, 2015 | Tablets & eReaders
Looking for either a code for a universal or a replacement rem for this unit ?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 22, 2014 | Prestige Fearless Leader Box Set Box New...
I want to delete books from cloud on my Kindle, is this possible?
Yes it is. If you delete a book from the cloud also known as your Amazon account, you will permanently lose access to that book.
On the Kindle, tap on books, and on the top will be cloud/device. Tap on cloud, find the book title or cover you wish to remove. Then press and hold on the cover. a mini menu will pop up. It will have an option to remove from cloud. Once tapped another window will pop up asking for verification that you are removing this, and you will lose all access to the title. Tap yes to complete this action.
Or
Sign into Amazon.com, put your cursor over "your account" and click "manage your kindle." Find the book and click remove. That will permanently delete the Kindle book you select.
Feb 13, 2014 | American Audio Amazon Kindle MP3 Player
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Hi, I have the ESPN college gameday remote and I lost the manual. Could someone please give me the code for a sylvania tv? Thank you.
Manually turn of the device the user wish to power scan (TV,PVR,DVD,VCR etc.
For more than 3 seconds press and hold the appropriate device key. The LED comes On, indicating that the remote is in programming mode.
Press and release the Power key. The LED blinks once and stays on, indication that the Remote is in power scan state.
Press CH up or CH down key repeatedly untill the device switches ON.
When the devise turn ON, press and release the SELECT key to program the remote with the new code and exit.
Mar 26, 2011 | Televison & Video
How do I get full control of all folders in my PC. I want to uninstall I-Tunes. Specificall "Apple Mobile Device Service.exe"
Logon as Administrator
>Go to Program Files (where most of the programs are installed)
>highlight the folders you wish to remove
>hold SHIFT and press delete then say YES
>this will remove the program PERMANENTLY
NOW, if the program you wish to delete is not on Program Files
>click on START
>go to Control Panel
>go to Programs and Features
>select the Program you want to remove
>click on Uninstall
Sep 19, 2010 | Computers & Internet
I cant connect it to my lg shine i lost the manual
press left soft-key to go into menu, scroll down to menu number 9; bluetooth, check that bluetooth is switched on (1st submenu), 2nd submenu 'search for new device'. To add a new device, press the left soft key [New] 1. Select the [New] key to search the device that can be connected and which is within range. 2. If you want to stop searching, press the right soft key [Cancel]. At this moment you press and hold the big button on the headset (supposed it was off), until the little light stays blue fixed (not blinking !!! it will blink when it turns on but you hold the button pressed until the light stays on permanently !!). At this time the phone should give a message "device found" or even "H350 found" or it will say it didn't find anything and should it "scan again". if so select yes. 3. All of the devices found are displayed in the pop-up menu. Select the desired device by pressing the OK key, and entering the password 0000 (4 times zero). The permanent light on the headset should go off and blink once every couple of seconds. The phone and headset are now paired. when you switch the headset back on (after having it switched off) it will be automatically recognized.
Jun 13, 2009 | Motorola Mobility H350 Wireless Headset
Dell Latitude CPt screen is black at startup and stays.
It sounds like your PC isn't completing its POST. (pre operating system test)
This is usually caused by faulty hardware. Your best bet is to first remove anything you have recently installed. If that doesn't apply/work, try removing various hardware devices (CD/DVD drives, memory, USB devices) until you get the machine to boot up.
If even after removing every piece of hardware possible the machine still exhibits the same behavior, it is likely a problem with the motherboard (or other "permanent" hardware).
Mar 18, 2009 | Dell Computers & Internet
Broken House Thermostat
You can hit the HOLD button to hold the temp indefinitely.
Jan 07, 2009 | Honeywell Programmable Thermostat Heater
Car Audio & Video Logo
32 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
