Question about Okidata 320 Turbo Printer (Remanufactured)
I have an okidata 320t that is loading wierd. The alarm light is on when I put a paper in the top feed the alarm light goes out, but the paper doesn't load untill you push the SEL button and then when you print one line it advances up about 2'' and comes back down to print the next line. Is there a default setting that I need top adjust or what.
  • kmoyes Apr 16, 2009
    Thanks for the attempt, but The paper will load but not unless you press the SEL button. and then when a print job is sent to the printer the paper backs up about 3 " and then comes back to it's original starting position. Is there a setting in the defaults that would make this happen, or is there somewhere I can find what the original default settings are?
1st try the easy stuff is the leaver set as paper feed or tractor feed if that is set correctly then you most likley have a gear problem and they need to be replaced.
open up the printer replace all the gears on the right side and the large gear on the left
they cost about 8 euros each and if it does not park correctly just clean out the bits of paper stuck under the paper load leaver the leaver is small black and bobs up and down if it does not bob up and down it means that there is a bit of paper stopping it. (to do this you have to remove the large black roller that feeds the paper)
thanks Hackeridis
Posted on Apr 16, 2009
Okidata 186 does not feed
Are you using pin feed or friction feed? Make sure the lever on the right is in the correct position.
Apr 08, 2013 | OKIDATA - DOT MATRIX New - Oki Microline...
Canon LBP 3300 printer A4 Paper is already loaded in Cassatt 1 but "Load custom paper in manual feed slot" massage shown when given print comment
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
Apr 16, 2011 | Canon LASER SHOT LBP 3300 Printer
Cant get my printer to line properly for invoice printing.
Setting Top of Form, Forms Tear-Off ON
(Step A)
! If you turn the platen knob when the printer is turned
on, you will cause the Top of Form to mis-align. Always
turn the printer off before turning the platen knob!
1 Turn the printer ON.
2 Park the paper.
3 With paper out of the unit, (red alarm light should be on)
press SHIFT (1) and QUIET/TOF (5) to reset the current
Top of Form.
4 Press FF/LOAD (3) to load the paper.
5 Press SEL/MENU (6) to take the printer off line.
The SEL light goes out.
6 Wait until the paper moves up to the tear position, then
press and hold TEAR (4).
The paper moves to the current Top of Form.
Keep pressing and holding TEAR.
7 Press and hold SHIFT and release TEAR.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 27, 2011 | Matrix Okidata Microline 320 Printer
I can't figure out how to feed paper into the printer
hello
i assume you refer to ML591, dot matrix ?
go to this link, and download users guied and/or manual http://my.okidata.com/PP-ML591.nsf?opendatabase
how feed the paper http://my.okidata.com/PP-ML591.nsf?opendatabase
Jan 11, 2011 | Okidata 591 Printer
Page length too short
Put it on 12" and try what happens. It should work.
Jul 10, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
JUST BOUGHT A OKIDATA 321 TURBO 9 PIN PRINTER OFF EBAY. WE HAD ONE BEFORE & IT QUIT WORKING SO WE ASSUMED WE COULD JUST PLUG THIS ONE IN & IT WOULD START WORKING BUT THE ALARM BUTTON KEEPS COMING...
If the alarm light is lit constantly it usually indicates that the paper is not loaded, it should go out when paper is loaded. If it is coming on and staying on for a while during printing then there is a problem with the paper out sensor and it may need cleaning. If it is flashing then the other lights that are lit indicate the problem.
Nov 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Paper jams consistely and then continues to feed, even if only printing one page
check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
Oct 24, 2008 | OKI C5100n Laser Printer
Okidata 395ML
Hi ,
make sure the cables to the main logic board are plugged into the correct places???
Dezzi
Jan 09, 2008 | OKI MICROLINE ML-395 Matrix Printer
Setting Oki3320 page feed
If you need Okidata Printer Customer Service, then you can contact with us, okidata printer support 1877-778-8#9#6#9.We are always here with tech team for your help. For further Info Click:https://goo.gl/Ltis3S
Aug 06, 2007 | OKI MICROLINE 3320 Matrix Printer
Okidata 320 Turbo Printer (Remanufactured) Logo
191 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
