Question about Hitachi 57SWX20B 57" Rear Projection Television
I have a Hitachi 57 " rear projection TV, the screen is dark
I have a Hitachi 57 " rear projection TV and the screen is very dark. What can I do to fix this? Is there a part that I can get that will fix this. 57swx20b is the model number that I have.
  • 1 more comment
  • jeffry_leste Apr 17, 2009
    the color got bad on the screen and i had someone come out to adjust the color/picture. Now it looks much better but it's dark. This guy told me that he thought one of the lenses? color? were going out on the tv and needed to be replaced. the Picture is still uniform
    the picture got bad over time. I had someone in that adjusted my system and now it looks good, it's just dark. This guy said that I have a lense? or color?going out and needs to be replaced. The picture is still uniform. In fact, it very good just dark.
  • Jim Krause May 11, 2010
    Did it go dark all at once or over time?
    Is the picture still uniform?
    President:
  • Hitachi Master
  • 1,779 Answers
Unfortunately it sounds like your CRT's ( picture tubes ) are getting weak. You have 3- red, green and blue. It would not be in your best interest to repair it because of the cost of the crt's and if we can still buy them. A lot of analog parts such as those are very hard to locate and is getting worse by the day.
Posted on Apr 17, 2009
  • 51 Answers
SOURCE: Sony KP-57WS500 57 in. Rear Projection Television
Hi Guys
Your problem here has to do with the amount of aging that happens to the three colour tubes - red, green and blue.
Blue actually ages slower than red and green. What actually happens is the green tube deteriorates and due to green being the predominant colour for brightness causes the blue tube`s flyback lines to appear - especially when switching between inputs or when the video is blanked.
No replacing the blue tube will not solve your problem as the tube is actually the best one of the three.
As someone mentioned there is a way to adjust this by removing the speaker grill assembly in front of the set. Doing the service mode adjustment with the remote is not the right way to solve the problem - you would be adjusting the colour gain and off-set values and would seriously be compromising the white balance of the set.
On the left hand side behind the speaker cover you will see a black square block with six adjustment points. Look for the one marked SCR BLUE, Switch the set to a unused input so the blue lines become visible. Now adjust the BLUE point counter clockwise until the lines disappear. A small adjustment should do it, Switch back to a picture and make sure the whites are still white.
This should sort your problem. I would however suggest asking a Sony service centre to do this for you. This is a dangerous thing to do as you will be working close to the 35Kv supply the the anodes of the three tubes.
I hope this answers your question.
Goo luck.
Posted on Mar 08, 2008
SOURCE: CONVERGENCE
50 in projection TV has horizontal blurring lines at the bottom half of the screen, picture visible , but blurred. Can you identify the problem and the fix?
Posted on Apr 23, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
SOURCE: looking for replacement screen for 57" Hitachi.
http://www.highdefforum.com/rear-projection-tvs/37146-hitachi-57f59a-screen-replacement.html
I have the same TV. I will be buying a replacement Screen for mine as well
Posted on Sep 26, 2008
  • 298 Answers
SOURCE: LOOKING FOR A SCREEN ASSEMBLY FOR A (HITACHI) REAR
Here's a link to order the original Hitachi screen assembly for this model (57F59A) from a major parts distributor:
Hitachi 57F59A Replacement Part Screen Assembly
Hitachi 57F59A Replacement Part Protective Screen / Super Shield
Posted on Apr 02, 2009
We have a Hitachi 57XWX20B Rear Projection TV. We moved this week and now the TV picture is very dark. We have tried the magic focus and adjusted the brightness, yet the picture is still very dark. Any...
one of two things on this model==clean the lens on top of the chassis--the round large black ones.
Second: there is a resistor in the power supply that changes value and will cause this----also with set unplugged and back off since set was moved carefully look for any plugs not fully seated etc.
Apr 10, 2012 | Hitachi Director's Series 57XWX20B 57"...
Hitachi model 57SWX20B which has a dark screen
loss of brightness could need the mirror and lens cleaned and also the screen.if the tv is over 8 years old then the crts are getting weak.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Need screen protecter
Here's a link to order the original Hitachi protective screen for this model (57F59A) from a major parts distributor:
Hitachi 57F59A Replacement Part Protective Screen / Ultra Shield
Mar 03, 2009 | Hitachi 57F510 57" Rear Projection...
Dark background blue tint
Try the Magic Focus option on the menu screen found under "Picture". Make sure the TV is on for 20 minutes before activating this option. It is also best to run this when the room is dark.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 57F500, Dark areas
Hitachi dark problems at ctechnicians.com
Dec 27, 2007 | Hitachi 57F500 57" Rear Projection...
Screen getting dark
Research at www.HitachiServiceUSA.com .......T.
Oct 20, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 57SWX20B 57" Rear Projection Television Logo
373 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
