Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Hitachi 42edt41 I have a broken flat flex cable that runs from the dvi input board to the pc board. It is about 3" long and has 50 connections. Tried contacting Hitachi and authorized service centers but they all just want to convince me i need a $100 service call...all I need is this stupid little flat flex cable!! Anyone know anything helpful?
    President:
  • Hitachi Master
  • 1,779 Answers
We have used the flat ribbon cables from a computer center in the past. Take the old one to a shop and see if they can accommodate you. Maybe they can modify one that will work. Let me know.
Posted on Apr 16, 2009
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How can I connect my Desktop computer to my Hitachi 57F500 TV? I have an emachines desktop, running MS Win 7 connected from Monitor VGA port to DVI port on TV via Dynex DVI-VGA cable, but not getting any...
Hello
VGA and DVI are not compactable. Your TV has no provision to connect it to computer.
DVI-HDTV Input (Input 1)
Use this DVI-HDTV Input for your external devices with DVI-HDTV output such as a Set-Top-Box, high-band DTV decoders, DVD
players and D-VHS with Digital Content Protection
1. Only DTV format such as 1080i, 720p, 480i and 480p are available for DVI-HDTV input.
2. The DVI-HDTV input is NOT compatible when used with a DVD player from a personal computer.
3. When connecting a Set-Top-Box with a copy-protect digital out terminal, a high definition picture can be displayed
on the screen in its digital form
OK.
Mar 23, 2011 | Hitachi 57F500 57" Rear Projection...
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
I want to connect a PC (VGA connector) to a Hitachi projector TV (channel 1: DVI connection). I want to find out what do I have to change in TV settings (like input type) and how.
Not all DVI inputs are the same. Do you have the manual handy to see if it supports analog DVI?
If it does, you should be able to just use A VGA cable with DVI adapter from your computer to the TV, Select the DVI input on the TV, and make sure your computer display settings are correct (this depends on a few things, so if you need help with that please reply back with more detail about your PC setup)
Dec 23, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Vertical bars on a Hitachi 42EDT41
Please see this link for a possible solution.....
http://www.fixya.com/support/t4491071-tv_two_black_vertical_bands_down
Mar 28, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
I have a hitachi tv model 42edt41 year 2004,2005
I have the same tv and had the same problem. I found a posting that stated to re-solder a connection on the cable for the "y" boards. I used this and my tv is perfect now. The part that needs to be re-soldered is the ribbon cables at the bottom of the tv that go from the boards straight to the screen. On the inside of this ribbon cables there are 4 small components that have "100" on them. On each end of each of these pieces, re-solder them. Since I had my tv completely apart I re-soldered all of them across the bottom. No problems now!
Oct 05, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hi can u hep? i connect my hdtv connector from my x box to a hitachi plasma 42 " tv which also acts as the pc port, but get no sound?
make sure that the connection you are using is providing audio to the tv. If it is VGA, or DVI, those cables do not carry audio, only video.
Sep 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
S video cable not recognized on Hitachi flat screen
I thought the TV had two S- video inputs... It doesn't. Pne of them was an out put and it was there that i had it plugged in. Once i switched it over everything was fine.
Feb 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
HDMI input
I am an authorized Hitachi servicer. I looked on the tech site for this model and I do not see any symptoms as you are having. Have you tried a new HDMI cable?? Please respond and I will take it from there.
Jan 07, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
106 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
