Question about Olympus SP-500 UZ Digital Camera
Camera has been flooded & wont work
It was soaked in fresh water for several hours & left to drain / dry out for a day or so.i tried to remove the back of the case but was only partly successful i managed to pull the cover away from the case so i could spray "electronic cleaning solvent no 1 " all round inside[i have used this before & it worked a treat. another camera] i allowed this to drain/dry for a long time.im unable to get it to go,hoping someone can help. thank you.
  • 531 Answers
This camera has BGA chips. Ones water goes inside, - that's it. Can't get it out with anything.
Posted on Apr 16, 2009
What can I do to turn on my digital camera after it was submerged in water?
First of all you should get (or have gotten) the battery out as soon as possible. You could try shaking excess water out of it. You should then put it in rice to draw all the moisture out of the camera. This may take a couple of days, maybe exchange with more dry rice after first day. When you are relatively sure all moisture is gone try reinstalling the battery. I will guess that you will only have a 20% chance of it ever working again.
Dec 21, 2011 | Canon Cameras
Accidentally soak in fresh water,after drying thru hair blower ,there is power but showing black the lcd
Probably no saving it but there is something you can try. Remove the battery and put the camera in a one gallon ziplock bag full of fresh uncooked white rice. Leave the camera and the rice sealed in the bag for about a week and the rice should absorb any residual water that may still be in the camera.
It is a long shot but it has been known to work.
Jun 18, 2011 | Canon Cameras
Hello my husqvarna 137 chainsaw wont start at all what should i do? it has fuel and oil but still wont start
Start with basic things first, drain the fuel tank and re fill with fresh fuel, remove the spark plug, is it soaked with fuel? if so dry it , put the ignition unit to off, with the plug still out crank the engine a number of times to remove any excess fuel in the bore, check there is a spark at the plug, if yes leave the saw to dry out for a couple of hours, refit the plug and try again, remember to switch the ignition on
Apr 05, 2011 | Garden
We used the camera in the ocean first time 10 days ago. We did not wash it afterwards. Was working fine till today. The lens wont open. The camera is dead. It does charge. HELP!
Unfortunately you have effectively destroyed your camera. Salt water is up there with fire and crushing as the absolute great unrepairables when it comes to assessing damage. Plenty of owners can and do repeatedly get away with what you failed to do, but you only need to be unlucky once.
Your camera is designed to be waterproof down to 10m (33') for up to one hour, but as with all such devices it must be thoroughly rinsed in fresh water after each exposure to salt water and then left well ventilated to dry. The user manual also clearly states this and gives particular instructions on the way to do so with slight differences depending upon whether the camera has additionally been exposed to sand or soil. A further preventative measure to protect your camera is to have the seals replaced at least annually as recommended by all waterproof camera manufacturers.
If the camera is not rinsed then salt crystals and/or rust form (stainless steel isn't totally immune to rust, and rust can form extremely quickly, especially in salt water). Whether it's salt cystals or rust the effect is the same as they will both tend to shift the waterproof seals slightly and allow water inside. It only takes a tiny drop of saltwater to get inside where, once trapped, it will gradually deposit corrosive and conductive salt traces which effectively destroy the electronics. Once it's in there the only slight chance of a fix is to remove the battery and memory card and then flood the interior with de-ionised water, but this has to be done immediately to have any chance of working. Your camera has now been left too long and so the damage is irreversible and in any case I know of no owner (myself included) who would have dismantled an apparently working camera to flood it with water unless it was known for certain that water had got inside.
Unfortunately your only fix is to replace your camera and to learn from your expensive mistake. I know of no professional repairer who will even attempt a repair to a flooded digital camera; there are simply too many expensive parts which must be replaced and there's too much chance of subsequent ongoing corrosion if even the tiniest mineral deposits remain in the camera.
Sorry I cannot offer you a more positive outcome, but I hope that you now understand why rising is vital and that my advice saves you from repeating the error.
Please take a moment to rate my reply, or if you have further questions regarding my answer then add a comment and I shall respond as soon as I can.
Sep 14, 2010 | Olympus Cameras
Flip camera fell in water at the mouth of the river... water was part salt and part fresh... soaked camera in fresh water for an hour or so after then let dry... plugged it into my computer... but...
Drying a camera involves burying it in a bowl of dry rice for a week before even attempting to turn it on. However, your camera was exposed to so much water, there may be no hope for it.
Aug 19, 2010 | Cameras
What do i do when my camera got wet and it wont turn on?
It all depends on if it was totally submerged or if it was slightly exposed. If it was totally submerged, there is not much to do at this point. It will need to be replaced. The entire unit will not work as designed, due to the severe water damage. Now; if it was slightly exposed to a minimal amount of liquid, simply, separate the internal component and batteries away from the cover housing and let them dry out for 5 full days. Once the dry out period has been completed, reassemble the unit and load a fresh set of batteries. It should work now.
NOTE_ The dry out method will not work if you have already tried to operate this unit shortly after the water damage occurred. Energizing a wet system board will cause a short,thus, damaging the entire unit.
Aug 10, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
DROPPED CANON POWERSHOT SX10 IS IN SALT WATER (NOT SUBMERGED). WILL NOT WORK. ALLOWED TO DRY OUT SEVERAL HOURS, INSERTED SD CARD AND BATTERIES. DOES NOT TURN ON.
First of all, it would take days, not hours to dry out. Turning it on too soon can fry the circuits. But worse than that, salt water is extremely bad for a camera. Most places won't even repair it.
Sep 25, 2009 | Cameras
Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
Jul 27, 2009 | 2005 Toyota Corolla
Jenn-Air JDR8895 dual fuel--ignitors won't work after flood
hi your ignitors wont last long, they are similar to a fuse, you should be able to change the ignitor and if it still does not ignite look to see the space of the ignitor and try shorten it.
Feb 05, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Camera got wet and now drains new batteries
Replace it a wet damged camera seldom survives
Nov 19, 2006 | Canon PowerShot A95 Digital Camera
Olympus SP-500 UZ Digital Camera Logo
96 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
