Need a manual
We own a used Roland Piano KR-75, but we don't have a manual. Any ideas?
    President:
  • 1,901 Answers
To download manuals Roland requires you to register. Go to:
http://backstage.rolandus.com/login.php
Create a new profile, then login to download the manual you need.
Thanks for using Fixya.
Posted on Apr 16, 2009
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
Service manual for the roland piano kr375
Your best bet would be to contact Roland directly to obtain a service manual. Go to the Support link at the top of this page- Roland
Jan 15, 2015 | Roland Music
I have a Roland KR 4500 Digital Piano and I brought it to the local authorized Roland Service Center here in the Detroit area. Apparently the capacitors on the motherboard leaked and the board is tot
You can sometimes clean up the board with a cotton swab and some alcohol. Trace the lines for continuity with a multimeter making sure there are no breaks. Get the information on the capacitors and buy them at an electronic parts store. Replace them or have a professional do it. If all fails, sell it for parts.
Jan 14, 2012 | Yamaha Music
Hi, I am undecided about which digital piano to buy: Yamaha Arius 141 or Roland F110? help appreciated, thanks, karol.
I have two Yamaha's and I will say they are maintainable. Almost ALL the weighted piano key models use a keyboard made by one company as I understand it. I can easily get service manuals for the Yamaha, not quite as easy for the Roland... same goes for repair parts. Your decision... listen to each and decide. Hint: Use a set of headphones to do the compparision rather than internal speakers as the orientation in a music store can drastically change the sound.
May 01, 2011 | Roland F110 Compact Digital Piano 4867
My Roland KR 650 digital piano, amplifier has a load hum and will not play.
smd elkos on the mainboard is defective 10uF16V and 3,3uF types
Aug 23, 2010 | Audio Players & Recorders
Does anyone have a parts list for a Roland KR-570 electronic piano? I need to find part numbers for the key-weight actuation mechanism.
Sorry I didn't find you 'til now. I just got the same problem.
If you haven't found out already, Roland has them available from the support dept. (323-890-3740) at $9.00 a piece or $200 for a full set of 88.
They say they've re-designed them to be more durable.
Jun 09, 2010 | Music
Roland KR-5500 digital piano When it warms up it begins to crackle and it smells like an electrical problem. I need a manual on the steps to properly remove the outer case to get inside to the electronics....
Unless you are skilled at electronics troubleshooting, you would probably be better off taking it in to be repaired. It might be the power transformer or a filter capacitor or a number of other things. The problem may not even be visible. You will definitely need a schematic and some test equipment. Try this site:http://www.vintageplanet.nl/ or this site:http://www.rangeraudio.com/stock16.htm
Oct 15, 2009 | Music
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Sep 21, 2009 | Music
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
